another update on the new throttle body
Old Oct 23, 2004 | 08:00 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i have been pretty busy lately and haven't had as much time to work on my intake stuff as i'd like. but, yesterday i drove the car around for a little while with the new throttle body all hooked up and working. it worked smoothly and i had no problems. throttle response was good and all. i did go ahead and make a spacer so that i could run in on the stock manifold. i have the materials that i need to make the new plenum and all but i haven't had time lately to do too much with that. but, it won't be too long...
Old Oct 23, 2004 | 10:42 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You should fab up spacers with a swirl grove in them. its the new thing in the car mag I got. TB spacers with a grove cut to swirl the air.
Old Oct 23, 2004 | 11:03 AM
Car: 91 Camaro
i've seen many TB spacers made that way. i don't really see the advantage to them but, i see even less advantage to something like that on a fuel injected motor. part of the reason for it under a throttle body injection setup or a carb is to help the air and fuel to mix. just having the swirls where there is just air passing through would probably hurt the airflow.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
