2.8 liter differances btw camaro and caveliar
Old Oct 27, 2004 | 09:33 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
I know this isnt totally thirdgen related but i need some help bad ok i broke the tensionor pulley bracket on my girlfriends 86 caveliar and cant find one in the junkyard anywhere. i was wondering the serpantine belt is setup the same way on the 2.8 mpfi camaros and firebirds. or more that the bracket is the same? thanx for anyhelp!
Old Oct 27, 2004 | 11:23 PM
KED85's Avatar
Couple of simple ways to find out
Parts store, go to belt parts book & answer may be there. IF same belt part number ya MAY be lucky.
Watch out! some "GENERAL" may complain about your choice of topic & request this thread get locked!
BUT I do not believe parts are same DUE TO the difference in FWD/RWD 60* cylinder head designs.
Doesn't mean ya may not get lucky BUT perhaps score a 3.1 FWD set up for your part ya seek.
Hope the girl is worth the trouble ya caused!
Old Oct 28, 2004 | 12:11 AM
KED85's Avatar
Another tip is go to the thread "What the Hell is This".
View the pic of 88 F Body engine bay.
IF idler looks the same you got a chance.
Old Oct 28, 2004 | 02:39 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
IS it the tensioner that is on a arm i believe and you ise a rachet to move it? if so you might want to try oldsmobiles at the bone yard they have the same 2.8 3.1 fwd engine i believe i think even some buicks may have the same enigne. So you are not limited to one year. But the part is not avaible through Autozone.
You might want to call the gm parts counter get the part number and buy it though GMpartsdirect.com.
Old Oct 28, 2004 | 03:38 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
thanx guys gm dealer discontinued the bracket. its the tensionor that has one bolt up top and two on bottom that loosen and allow tensionor to slide.
Old Oct 28, 2004 | 03:41 PM
KED85's Avatar
Did that pic on thread offer ya any help?
Fast RS knows as he had the two cars side by side to check out at some point in past, I recall.
Old Oct 28, 2004 | 04:45 PM
FAST RS's Avatar
Is it the setup where you have to turn one big bolt to move the ensioner up and down? Or is it the setup where it has a spring in it that will put tension on the belt on its own.
Is it a single belt that runs the car with i belive 6 ribs in it?
Old Oct 29, 2004 | 12:55 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
well it actually slides left to right with the two bottom bolts loosened but it has no spring
Old Oct 29, 2004 | 04:21 PM
FAST RS's Avatar
That is a very different setup then what the both of my cars had. Best bet is to look at many different years and models of GM cars at the boneyard since GM used the same parts on different models. Or see if you might be able to get a spring loaded tensioner from a FWD v6 and see if that may be able to bolt in place. I dont think it will but it may be worth a try.
Old Oct 29, 2004 | 09:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Nope not even close to the same. You need to expand your search from Cavaliers to other FWD GM applications. I know the Corsica, Lumina, Citation, Pontiac Sunbird and a few other have these brackets.
Worse case senerio you could get it tig welded, try finding an ALT bracket for an 80 vett.
Old Oct 29, 2004 | 10:38 PM
KED85's Avatar
You want an alternator bracket for an 1980 Corvette?
Send me an email before noon-ish PST & I'll give ya a name & phone number.
NOT a problem for me.
I'll bet I can supply two sources, one I know out here in LA, CA (Bellflower, actually). Other back in PA & you'll probably have to phone the PA one on Monday.
PS Mine broke on my 1974. I threw the belt, chipped into hood (I still see two fiberglass flake spots). That breakage was the actual fist time I was ever stranded in my Corvette. Took me MANY HOURS to drive home due to "overheating". Made it tho!
You have same as mine, under support, with an arm on top.
Hope this helps
Save the Wave!
Old Oct 31, 2004 | 04:15 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Actually is was about a year ago when I broke the second peice from the bracket. I was on a customers car too.
I had to get it tig welded cost $25 but saved my butt. The only problem I had with getting this fixed was a few spots had to be grinded down.
Old Oct 31, 2004 | 04:41 PM
KED85's Avatar
Ready?
I replaced mine for $15 from my buddies in Long Beach area (actually Bellflower).
It's cast iron & I wasn't gonna waste effort "your way" (understand NOT a put down!!) due to a call & a $15 check solved my problem.
I discovered to keep alt. belt proper tension after that episode! And I learned how to rebuild an alternator for $9 kit from Pep Boys, too.
Gotta love old cars!
PS Wish I could have found a way to rebuild the Firebird alternator for only $9! kit LOL.
AND I'll bet the customer never knew what happened! cause ya can't see down there once alternator in place.
Old Nov 2, 2004 | 01:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep the guy bever knew anything broke.
I have a few vett sources in in colorado, I guess the claim is one of the biggest used/new corvette dealers is in colorado springs about an hour away. I'm just lazy when it comes down to it.
Old Nov 2, 2004 | 06:39 PM
KED85's Avatar
I LOVE SCROUNGING AROUND CORVETTE WRECKING YARDS!
LOTS OF "Little" things end up in my pocket.
Try finding a good original one year rubber button for the under hood shut off switch for seat belt interlock starter system.
Remember those things?
My 1974 (the one year) Corvette still has all that stuff, disconnected, yes, but....
I found it in a Back East PA wrecking yard for Corvettes! They do deliver, too. But I had to find my the scrounger method!
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
armybyrd
Aug 10, 2015 09:23 PM
