Help me Please again???
Old Nov 5, 2004 | 09:26 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Well today i decided to wash my motor compartment, soaped it all up when it was warm, started it up and started washing it. After I was done, drove the car down the street and then back home, let it sit for about 20 mins, went out started it, started first turn, but turned over at like 200-300 rpm then i gave it gas and it shoot up to around 2100 rpm. The car refuses to idle now, lowest it idled tonight was 1800, the car seems to have lost a lot of power, I also noticed it was bacfireing threw the air cleaner when i floored it. What could I have done now? I was thinking water in the dist cap, but all that is new, but still maybe, although last time i had that the car did not run at all, what do you think the problem could be now? Any help would be great, i'm a little worried Thanks
Old Nov 5, 2004 | 11:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did I read right, you washed the engien while it ws running???? And what did you wash it & rinse it with????
Old Nov 6, 2004 | 03:10 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah i was told to have the motor runnign when i washed it, i used simple green and rinsed it with water? What did i do, today i check the dist cap, its good, check the IAC, clean it, seems fine, and also disconnected the TPS to see what it would do, nothing, any help would be great, it still doing the same
Old Nov 6, 2004 | 03:31 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
nooooo, you gotta turn the engine off when you clean it
Old Nov 6, 2004 | 04:04 PM
Engine: 2.8 Lt
Transmission: 5 Spd
That prob would have been great to know before. Now what do I do, the thing is running like crap. All the sensors are new on it to, could one be bad, when u start the car it barly runs, then u give it a lil gas and it jumps to about 2000 rpm and stays there, then if ur drving and u give it a good amount of gas u can here it back fire from the front of the motor. I was thinking TPS or IAC or MAF, all are new though which i don't understand. WHat can i do guys, this is a daily driver, i hope i didn't screw myself over, Thanks
Old Nov 6, 2004 | 04:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
my guess is you shorted one of your sensors, i'd say the tps or maybe messed up the iac
Old Nov 6, 2004 | 04:11 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah but when i unplugged both, the idle still didn't change . I will say this, when i was done washing th ecar i drove it around the block, ran fine, then parked it for 20 mins, and then that was when it gave me the problems. Is there I way to test this? Thanks
Old Nov 6, 2004 | 04:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
car throwing any codes? and how long ago did you do this?
Old Nov 6, 2004 | 04:37 PM
Engine: 2.8 Lt
Transmission: 5 Spd
No codes at all, i did this yesterday night
Old Nov 6, 2004 | 05:01 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
give it a few days, something may of just gotten wet and screwed it up.
