Getting colder, blower motor not working. Need some help.
Old Nov 15, 2004 | 09:59 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I am having problems getting my blower motor to work. I pulled the v6 out in may and put in a LB9.
I think the problem lies with a plug that is not plugged in. In the same area my blower motor plugs in, i have a plug with 2 green, 1 red, and 1 black wire that is not plugged into anything.
Its a rectangular plug, any ideas?
I will put a picture of the plug up later when i can.
Old Nov 15, 2004 | 10:14 AM
9D1BURD's Avatar
Car: 1997 Z28
Forgot to mention, no power to the plug, and fuse is good.
Old Nov 15, 2004 | 10:40 AM
9D1BURD's Avatar
Car: 1997 Z28
One more update, when i hooked up my voltmeter to theplug in question, i had 0 volts with the fan switch off, and 12 with it on. So i am assuming that is my problem. But what goes there?
Old Nov 15, 2004 | 10:51 AM
9D1BURD's Avatar
Car: 1997 Z28
Last thing, when i check the actual blower motor plug, i get voltage on the ground wire, but non on the power wire?
Old Nov 15, 2004 | 11:40 AM
9D1BURD's Avatar
Car: 1997 Z28
Here are links to the pics
one
two
three
Old Nov 15, 2004 | 02:21 PM
9D1BURD's Avatar
Car: 1997 Z28
TTT
Old Nov 15, 2004 | 02:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Seems like your voltmeter says the motor's shot.
Old Nov 15, 2004 | 02:56 PM
9D1BURD's Avatar
Car: 1997 Z28
I bought a new blower motor and still no dice.
Old Nov 15, 2004 | 05:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I shoulda told ya to hook the blower motor up to the battery directly and see if it spins... but I guess you can take the new motor back tho.
Old Nov 15, 2004 | 08:59 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Man i had the same prob, i brought it to a garage and they couldn't figur it out, they spliced into a power source and now it blows fine. Let me know how you make out? Thanks
Old Nov 16, 2004 | 12:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey 9D1BURD, as far as that connector goes, this is about the only thing that I can find that is in that area.
Attached Thumbnails Getting colder, blower motor not working. Need some help.-timing-est.gif
Old Nov 16, 2004 | 07:31 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
as stated above.. it right by the blower
Old Nov 16, 2004 | 07:52 PM
9D1BURD's Avatar
Car: 1997 Z28
Thanks a ton dave, now the question is, what exactly is that
Old Nov 16, 2004 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It connects into a wire harness that goes to the A/C low pressure cycling switch in the side of the accumulator. See the item going into the accumulator just above the time stamp in Dave's picture and to the right of the dust cap on the schraeder valve..
Old Nov 17, 2004 | 09:03 AM
9D1BURD's Avatar
Car: 1997 Z28
Thanks everyone for all of your help. I think i have enough to get it going now.
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
