who sells underdrive pulleys for our v6's?
Old Nov 19, 2004 | 06:43 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i'm looking for some underdrive pulleys, but summit has nothing, and neither do any of my local shops.
i know theres a bunch of you with them, so where do i get them from?
Old Nov 19, 2004 | 08:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
aspracing.com
Old Nov 19, 2004 | 08:57 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thanks dale, any ideas where i get a new belt for it?
Old Nov 19, 2004 | 09:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you do what I did when I had the 3.4 swapped in, trial & error.
OR
find out how much percentage bigger/smaller the pulley's are from stock, and adjust for the new belt. yes,it does involve math
Old Nov 19, 2004 | 09:34 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yep, gotta bring out the old calculator and do the math
Old Nov 20, 2004 | 01:04 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
summit didnt list any....boy thats funny thats where i got mine
got a crank and alternator pulley for like 60 bucks maybe they dont carry it anymore who knows. call back and ask someone else some of those guys arent to smart
Old Nov 20, 2004 | 01:14 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Kretos, I bought my ASP pullies from Summit also.
I will preach again and I speak from 1st hand experimenting with the pulleys and 3 different size alts (108amp, 140amp and 200amp) Do not use the alternator underdrive pulley! Just buy the crank underdrive pulley. I could not even use my 200amp alt with the alt underdrive, it still discharged at idle. The alt just does not turn fast enough at night with the headlights on, the alt pulley reduces the revolutions too much.
Here is a link to belt info.
https://www.thirdgen.org/techbb2/sho...ight=ASP+crank
Reduce your current belt length by 2" if installing an ASP crank underdrive pulley.
Old Nov 20, 2004 | 01:20 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thanks, just outta curiousity, i'm thinking of ripping out the air and smog pump, am i looking at any ill effects?
Old Nov 20, 2004 | 01:37 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Yep, your car will have more power do to having to turn less rotation mass. Thats the kind of ill affects I think you don't mind though
Old Nov 20, 2004 | 01:48 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
is it really gonna effect my emisions?
i wouldn't think it would affect much, but who knows?
Old Nov 20, 2004 | 07:03 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
in a 3.1l do you need the smog pump replacement pully to pull the smog pump? The way the belts are you can't just bypass, you gotta reroute the belts.
Old Nov 20, 2004 | 12:22 PM
Pillsbry10's Avatar
nope just pull the pump plug anything that needs to be pluged and messure for the belt length, simple as that....at least for the smog pump. i still like being cool in the summer =) so air is still in, for now
Old Nov 20, 2004 | 04:38 PM
Dale's Avatar
Engine: 350 S-TPI
3.1 belt system
removed smog
underdrive crank
I had to make a custom alt bracket to make my belt tight enough.
Old Nov 21, 2004 | 09:42 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I tried skipping the air and the belt rubbed on the waterpump pully so I need a replacement pully for that I'm guessing. I would like to bypass it though since my a/c needs to be recharged anyways, would rather just dump it.
Old Nov 21, 2004 | 11:38 AM
Dale's Avatar
Engine: 350 S-TPI
Nocturnall, the 3.4 power steering pump bracket sits it a little higher then the 2.8/3.1 bracket. Might want to look into that as someone else on here has done this.
Old Nov 22, 2004 | 12:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Couldn't you also just take a rope, tie it around the original pullies and then mark it? Then install the overdrive pullies, tie the rope around again, and mark it a second time, and then just go by the difference of the two marks?
(By doing a before and then after measurement, the lack of tension on the tensioner shouldn't matter- if that made sense )
Old Nov 22, 2004 | 02:01 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
You all forgot Jet they make a set of underdrive pulleys for our cars.
Old Nov 22, 2004 | 02:36 PM
Dale's Avatar
Engine: 350 S-TPI
I know jet makes them, but I refuse to buy from jetchip anymore.
Old Nov 22, 2004 | 06:14 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
i didnt look at the other places, what kind of prices they have, but you might want to check these guys out, they make an UD pulley for the 60*v6
http://www.fastfwdperformance.com/
Old Nov 22, 2004 | 07:45 PM
Dale's Avatar
Engine: 350 S-TPI
cool link. Wonder if FWD crank pully is same as RWD?
Surprised they dont make anything for the GTP's yet, thats kinda why I looked
Old Nov 22, 2004 | 10:54 PM
PhantomFE3's Avatar
Car: 1984 Z28
i would imagine it would be the same for all 60*v6's..
yeah the aftermarket for w-bodies is extremely limited, i used to have a cutlass but fried the tranny, never got a chance to soup it up.. heh..
Old Nov 23, 2004 | 01:35 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i'm wondering this too, you'd think its all the same, but hwo knows
Old Nov 23, 2004 | 12:40 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Summit has them, you just have to search under the part number. A general search will not pull it up! they were out of stock when i ordered. I think I order direct from Asp...
Old Nov 23, 2004 | 12:42 PM
redraif's Avatar
We aproximated. Put on the original belt after the install of the new parts. I pulled the tensioner to get anidea where it needed to be to do its job. Joe then pulled up the slack i the belt and measured. Then bought about 5 belts till we got the right one and returned the rest. Autozone barely had the right size. My car is a non smog car. It also did not come with a factory idler pulley. I had to get a junkyard one and install it. Otherwise I was having belt issues. The smallest belt would not fit w/o slipping.
I only installed the undrive crank pulley. But the alt still would not keep up with the Factory pulley. So i wanted a nicer Billet pulley anyway...installed the smallest alt pulley from March. Had to have it machined, not enough length on the shaft to fit the nut and lock washer... Hey but its now been working just fine, knock on wood!
Depends on the local laws. I'm in GA, very near the city. My car passes with no Egr or smog pump. And its got a beefy cam, bigger injectors, & high flow cat. Just have to be sure its been run a while first and does not sit. Also the timing has to be set to 10. It even passed with the 3.4. they put it in as a 3.4!
Old Nov 23, 2004 | 01:03 PM
redraif's Avatar
3.1 belt system
removed smog
underdrive crank
that was why we had to go to the darn GM idler pulley
Old Nov 24, 2004 | 12:31 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thats good to hear, we have fairly lax emmisions up here
Old Mar 29, 2005 | 05:19 AM
firestorm's Avatar
Car: Firebird
Engine: LG4
Do you happen to have a part number on the smaller pulley. Was it for a v-belt? Thanx
Old Mar 29, 2005 | 11:48 AM
redraif's Avatar
March’s Alternator Fan (MCH-221) and pulley w/ cover (MCH 112).
My original March pulley was the diameter of the stock pulley and was not charging enough. This one is the smallest that March has, I believe, and it did the trick for me! Hey and it even looks pretty too!
But like I said I had to get a shop to machine the center down slightly since the shaft on my alternator was not long enough to accomidate the lock washer. Then we added blue loctite to be sure there was no chance of it letting go, but so we could still get it apart!
Hotrodboba400
Dec 10, 2019 07:07 PM
Stangski09
Nov 14, 2015 01:27 PM
scottmoyer
Sep 7, 2015 07:06 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
