Serpentine belt routing
Old Nov 21, 2004 | 10:47 AM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I need a pic of the routing for a non AC v6 car. Please somebody
Old Nov 21, 2004 | 02:45 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
give me a minute and i'll go take a pic
Old Nov 21, 2004 | 06:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ya know; I had a picture that someone drew for me... can't find it on my computer. I'd like to see that picture too! (Someday I may swap to serpentine drive so I can use an underdrive pulley set)
Old Nov 21, 2004 | 06:50 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i can tell you what it is, since i just redid my computer. from the crank, the belt goes around the p/s pulley, straight across to the tensioner, around the outside of the alternator, to the waterpump and down to the crank. this may not be too clear, but i havent put the pics back on my computer yet, sorry if this isnt too clear.
Old Nov 21, 2004 | 09:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ah my cam won't work, but hes right, it goes alternator smog crank back around water pump over power steering , then tensioner
Old Nov 22, 2004 | 10:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are these close?
Old Nov 22, 2004 | 10:57 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Belt routing for a 2.8 serp.
Old Nov 22, 2004 | 11:11 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Here is the factory label showing belt routing with AND without smog pump. 1987's did not have smog pumps.
Old Nov 22, 2004 | 12:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the label pic! That doesn't make sense then for a non-ac car; if it goes right from the p/s to the tensioner, doesn't the belt rub against the water pump belt that goes the other way?
Or did non-ac, serp belted cars have their p/s pump mounted higher?
'Cause going by Dean's pic of his engine, if there was no a/c, I don't see how the belt can go straight from p/s to tensioner.
You can actually see my confusion in my ultra-bad drawings... looks like the belt will rub against itself above the water pump.
Old Nov 22, 2004 | 12:11 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
You are correct Tom, If it is a NON A/C car it still has to run a dummy pulley in place of the A/C compressor. There is no way to run the belt from the tensioner directly to the powersteering pump pulley without it rubbing.
I have a GM A/C delete pulley on my Chev truck that will work on the 2.8 A/C compressor mount. That GM A/C delete pulley was a factory option for the IROC 350 cars. I someone wants, I will take a pic of it and supply the part #.
Old Nov 22, 2004 | 06:15 PM
sixbanger's Avatar
Thanks for the pics. Got it now.
Old Nov 22, 2004 | 07:26 PM
drdave88's Avatar
Engine: 6.0L
on my 88, there is no A/C, but there isnt a dummy pulley. it comes close to the waterpump pulley, but does not rub on it. there is an inch or two of clearance
Old Nov 22, 2004 | 07:30 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
same here, tight fit but no rub
Old Nov 23, 2004 | 12:44 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
tomp, I just noticed that bottom drawing, w/o smog is wrong.
It goes from the alt, down to crank, then up to wp, then over to ps.
Old Nov 23, 2004 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ah, gotchya; I guess with my drawing, the ribs are facing the wrong way AND I've reverse-rotated the water pump!
I'll have to correct that drawing so nobody uses it by accident... maybe I'll even make it pretty.
F-body-fan
Jan 12, 2023 01:49 PM
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
