Or know the formula?
Thanks,
Jim
Thanks,
Jim
There is a chart on the link I am attaching- however, the 3.4 they reference is the FWD blocks, not the RWD ones.
http://users.spec.net/home/emxjc/block.html
Ok, the stock bore for the RWD is 3.62, right. Is there really enough thickness to the cylinder walls to bore off .070"?
you give me bore and stroke, I'll slap it in DTD2000 and let you know.
Quote:
I really think that is pushing it into no mans land. You are getting into too thin of walls. I think .050 over would be max for most blocks and even then it really does mine checked before I have it taken out .040.Originally posted by Jerriko 3.4
The formula is really easy, elementary school math:
BORE^2 / 4 * PI * NUMCYL * STROKE
If you supply measurements in inches, you get cubic inches.
If you use millimeters, divide the result by 1000 and you get cubic centimeters.
Hope this helps.
Lou
Hope this helps.
Lou
Hope this helps.
Lou
Thanks, that's what I was looking for.Originally posted by BigBabyLou
Hope this helps.
Lou
Hope this helps.
Lou
fantastic, thanks man this is greatOriginally posted by BigBabyLou
Hope this helps.
Lou
