turbo question?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yes, and no... the stock computer can read boost, but only after doing some modifications
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
If the pinout is the same as the V8 7730, this thread will contain the info you need for the repin, as well as links to sites that are centered around the 730->749 repin. (you don't actually need the 749, you just have to repin and use the same code the 749 does)
https://www.thirdgen.org/techbb2/sho...hreadid=221968
