DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
1227302 to 1227165/730/749 swap
Old Feb 3, 2004 | 02:31 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
1227302 to 1227165 swap
New primarily theoretical line of discussion... unless there's a MAF sixer out there who wants to use a P4 ECU. Probably going to be doing a 7302 -> 7749 swap, but this is the easiest stepping stone (documentation-wise) to work out the bugs since 302 and 165 are fairly similar and 165 -> 749 is documented already.
Current Info: Pinouts (without matching pin names)
http://www.cruzers.com/~ludis/1227170sheet4.gif
http://www.cruzers.com/~ludis/1227165sheet5.gif
Also unsure if the 7170 is the exact harness pinout for us LB8 guys. Planning on research here, but if anyone has some knowledge to throw in, please, by all means. As soon as I finish the list of pinout gripes I'll post it.
Old Feb 3, 2004 | 03:34 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Link which further identifies some 165 pins
http://speedtoys.com/~bort62/7749/86to92.txt
Old Feb 3, 2004 | 04:19 PM
TechSmurf's Avatar
Engine: LS1, Scrap
More links, more identification.
Good page with general info on 165 pinout
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
which leads to this diagram with full descriptions and WIRE COLORS.. behold
http://www.eecis.udel.edu/~davis/z28...165v8tpi-6.jpg
I think we've got all the 165 info we need... now, if someone wouldn't mind actually giving me a bit of a hand, some info on the 302 would be much appreciated, because it's *not* out there.. and I know there's experts floating around here with more info than we really want to know about stored in their heads...
Old Feb 3, 2004 | 04:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1227302 to 1227165 swap
I was wondering when someone would do this swap. For full wiring diagrams of the '165 as used in f-body's go here: http://www.diy-efi.org/gmecm/ecm_info/1227165/
You may be able to ask Mr. TuneUp (over on the v6 board) if he can get you the wiring diagrams for the V6 MAF harness. Between the two the ECM swap will be much easier.
As for the MAF itself IIRC the V6 MAFS are a frequency output. There are two different code masks that run in the f-body '165: $32B & $6E. Only the $32B mask can handle the frequency MAF. Of course can swap to a V8 analog MAF and use either mask.
RBob.
Old Feb 3, 2004 | 04:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Exactly what are you trying to accomplice?.
If you want a v6 P4 high frequency MAF then you might investigate the 8352. While the cal only goes to like 170 Gm/sec, using an LT MAF and frequency charts would give you the 255.
All in theory mind you, the 8253 being for DIS, you'd have a steep curve on learning the ecm but it'd be kinda neat, I think.
Old Feb 3, 2004 | 08:59 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I'm just trying to accomplish gathering enough information to feel 100% certain about the swap. In reality, I won't be facing the MAF issue, since as I said I'm heading in the Sy/Ty 7749 direction... the 302 and 165 use a very similar pinout.. many seem to match up directly.
Seeing as the 302 to 165 swap seems fairly straight foward, once enough data has been gathered to go 165, using the 165 to 7730 and 165 to 7749 swap guides opens up pandora's box for the V6s. I'd really prefer to move away from maf, but this is just the easiest step to get the project to a point where readily available documentation becomes useful.
I've been staring at pinouts of the 165 from various sources and the one pinout of the 302 that I have, and should have an initial pinout conversion alpha chart tonight for review.
Old Feb 3, 2004 | 09:23 PM
TechSmurf's Avatar
Engine: LS1, Scrap
ftp://ftp.diy-efi.org/pub/gmecm/manu...9-165v8MAF.jpg
Particularly useful. Thanks, Rbob.
A PM to TomP will be out hopefully getting him to chime in momentarily. Good suggestion, was considering it myself. Call it a majority vote now
Yep. Ghetto V6 mafs are frequency film. One of the main reasons I would do this, were I going to do this, or if I do this, would be to get a hot-wire MAF so I can run blow-through. If anyone wants to do this and keep the frequency film MAF, power to them, but I'm not doing the footwork there.
Old Feb 3, 2004 | 09:55 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Pulled, new diagram below.
(These diagrams are huge.. one per page is enough )
Old Feb 5, 2004 | 05:24 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Showed up in the snail-mailbox today. Scanned and posted. . . '87 MPFI V6.
RBob.
Attached Thumbnails 1227302 to 1227165/730/749 swap-87mpfi-v6-2a.gif
Old Feb 5, 2004 | 06:05 PM
Doward's Avatar
That's a big.... You Rock!
Old Feb 5, 2004 | 08:31 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Rbob...
:hail: :hail: :hail: :hail: :hail:
Old Feb 5, 2004 | 09:19 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Pinout Swap Diagram, take 2
Code:
Pin	302			165			SOLUTION
A1	Fuel Pump Relay		Fuel Pump Relay		OK
A2	A/C Clutch		AIR Valve - Port	DISCONNECT
A3	AB_GATE			Evap Purge		OK
A4	AB_EGR			EGR Control		OK
A5	SES			SES			OK
A6	VIGN			VIGN			OK
A7	AB_TCC			TCC/SHIFT		OK
A8	ALDL			ALDL (data)		OK
A9	DIAG			DIAG (mode)		OK
A10	VSS			VSS			OK
A11	MAT			MAF GND			302 A11 -> 165 C12
A12	GND			GND (Chassis)		OK
B1	BATT			BATT			OK
B2	Fuel Pump Signal	Fuel Pump Signal	OK
B3	ESTLO			EST Ref Low		OK
B4	EST			-UNUSED-		302 B4 -> 165 D4
B5	ESTHI			Dist. Ref (ESTHI)	OK
B6	MAF Signal		VATS (Unused)		302 B6 -> 165 B12
B7	KNOCK (Unused?)		KNOCK			OK (No Knock Sensor?)
B8	A/C Request		A/C Request		OK
B9	PSPS (power steering)	-UNUSED-		DISCONNECT TPI =No PS Switch
B10	Park/Neutral		Park/Neutral		OK
B11	-UNUSED-		-UNUSED- (ESC)		OK
B12	-UNUSED-		MAF Signal		302 B6 -> 165 B12
C1	no connection		FAN			302 D2 -> 165 C1
C2	AIR Conv Solenoid	AIR Conv Valve		OK
C3	IAC BLO			IAC "B" LO		OK
C4	IAC BHI			IAC "B" HI		OK
C5	IAC AHI			IAC "A" HI		OK
C6	IAC ALO			IAC "A" LO		OK
C7	-UNUSED-		-UNUSED-		OK
C8	4th Gear Signal		4th Gear (Unused?)	OK
C9	A/C Fan Req		-UNUSED-		302 C9 -> 165 D11
C10	CTS			CTS			OK
C11	-UNUSED- (MAP)		-UNUSED- (MAP)		OK
C12	TPS Back-up		MAT Signal		302 A11 -> 165 C12
C13	TPS Signal		TPS Signal		OK
C14	TPS +5V Reference	TPS +5V Reference	OK
C15	-> D14 (INJ135)		EGR Diag		302 D8 -> 165 C15, 302 C15 DISC
C16	BATT			BATT			OK
D1	GND			GND (Chassis)		OK
D2	FAN			GND (CTS/TPS/MAT)	302 D2 -> 165 C1, 302 D13 -> 165 D2
D3	-UNUSED- (8CYL)		GND (Chassis)		OK (May require no ground)
D4	-UNUSED-		EST (Ctrl)		302 B4 -> 165 D4
D5	BYPASS			BYPASS (EST)		OK
D6	02LO			O2LO (GND)		OK
D7	O2HI			O2HI (Signal)		OK
D8	EGR Diag Switch		-UNUSED- (MAP2)		302 D8 -> 165 C15
D9	-UNUSED-		-UNUSED- (INJSENSE)	OK
D10	GND			GND (Chassis)		OK
D11	-UNUSED-		A/C Pressure Switch	302 C9 -> 165 D11
D12	GND/UNUSED		MAF Burn Off		DISCONNECT, New wire if needed
D13	GND (CTS/TPS/MAT)	-UNUSED-		302 D13 -> 165 D2
D14	INJ135			-UNUSED-		302 D14 DISCONNECT
D15	INJ246			INJ (1357)		302 D15 -> 165 D16
D16	-> INJ246		-> INJ (2468)		302 D16 -> 165 D15
This leaves the non-OK as:
Code:
B7	KNOCK (Unused?)		KNOCK			(No Knock Sensor?)
Which gives us what appears to be a good conversion.
Harness repin, in 302 order
Code:
A  2 --> DISCONNECT + Insulate
A 11 --> C 12
B  4 --> D  4
B  6 --> B 12
B  7 -- New wire to ESC module pin B (unless
        we really do have a knock sensor already)
B  9 --> DISCONNECT + Insulate
C  9 --> D 11
C 12 --> DISCONNECT + Insulate (!!!)
C 15 --> DISCONNECT + Insulate (!!!)
D  2 --> C  1
D  8 --> C 15
D 12 --> DISCONNECT if present, new wire needed for
         MAF Burn-off relay if using Hot-wire MAF
D 13 --> C  2
D 14 --> DISCONNECT + Insulate (!!!)
D 15 --> D 16
D 16 --> D 15
ALDL E --> ALDL M
Need to make sure MAF is grounded after this swap, as A11 is left empty. 165 may want MAF ground at pin A11. This will require actual testing. Please feel free to post any other issues you see.
Old Feb 6, 2004 | 07:45 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Here's that Pandora's Box I was talking about...
Code:
Chart removed.. again, one of these giant things per thread is enough :)
It could be a *while* before I finish the javascript that should make that whole table make sense.. so if you're feeling gutsy, work with that thing for now.
There may also be an ERROR concerning the translation of the terms "A/C Fan Request" and "A/C Pressure Switch" ... not quite sure what to do with it.
Old Jul 25, 2004 | 03:53 AM
TechSmurf's Avatar
Engine: LS1, Scrap
This thread is going active again!!! *pats the 749 sitting next to him*
I'm going to be going over the data on the repin over the next couple weeks preparing for a dry run (power only) and add one system at a time, making sure everything works. Figure 2-3 months before I'm done with the swap, working on it every once in a while.
Old Jul 26, 2004 | 06:13 AM
TechSmurf's Avatar
Engine: LS1, Scrap
If someone can find *this* image (all ECU pinouts, their name, and exactly what they connect to, with pretty drawings, on one page, or two considering the extra connector the 749 uses) for a Syclone, Typhoon, or Turbo Sunbird, I will love you forever.
Old Jul 26, 2004 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not exactly the same but over on gmecm, under ECM's, 1227749 is the Turbo Sunbird. Someplace on incoming are the Sy/Ty's (SyTyWiring.zip).
RBob.
Old Jul 26, 2004 | 12:30 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Said file is in ftp://ftp.diy-efi.org/uploads/
Thanks, didn't think to check in there... but it's still not exactly what I was looking for. The incomplete multi-page sunbird ones have also been sitting in my printer output tray since before I made that request. I'm looking for that particular image because of how complete it is.
Old Jul 28, 2004 | 04:13 AM
TechSmurf's Avatar
Engine: LS1, Scrap
It's coming together a bit more
Code:
Chart moved... agian....
Old Dec 17, 2004 | 01:14 AM
TechSmurf's Avatar
Engine: LS1, Scrap
And here's a 302->749 adapter, mostly complete
Attached Thumbnails 1227302 to 1227165/730/749 swap-100_0481.jpg
Old Dec 17, 2004 | 09:26 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
youre crazy
Old Jan 7, 2005 | 07:44 PM
TechSmurf's Avatar
Engine: LS1, Scrap
29C256s are in... buddy ordered the wrong ZIF sockets though. don't particularly even want to attempt connecting the huge aries ZIF to the memcal, so waiting on low profile sockets. ah well
Old Jan 14, 2005 | 05:59 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
Nice work TechSmurf! Looking forward to the next update...
Old Feb 14, 2005 | 12:48 PM
Geyservillebob's Avatar
Car: '63 Nova Wagon these days
Engine: 3.1L V6
Transmission: 5-speed
Ok, as one of those types this is quite interesting.
Lots of questions but one that bugs me is that the 165 appears to have only one injector driver (D15 and D16 connected together) at least according to the schematics. However, the pin outs for the V8 cars show two outputs for each bank of injectors.
Is there one driver or two in the 165? Are the schematics wrong? If there is only one driver is it compatible with the driving all the V6 injectors at once?
Frank
PS: If this belongs in a separate thread let me know.
Old Feb 15, 2005 | 08:15 AM
88to85rescam's Avatar
Car: 97' aurora and 85 camaro - 88 camaro
Engine: 355 tpi and 4.0 northstar
Transmission: 350 turbo and 700-r4
You guys know a lot more, ok everything about this than I'll ever know, but can I get a little bit of that knowledge from you?
How do you feel about the pinouts under the dash of an 88 L98 camaro on the ecm and the pinouts on the harness under the dash of an 85 camaro with the 4 bbl carb 305?
Can I just plug in the 88's ecm or will I need to change dash over if I dont want to repinn?
Old Feb 15, 2005 | 01:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Frank
Both the '165 and the '730 ECM have one injector driver. Either ECM can drive up to 8 saturated injectors.
I'd bet the '7302 also has one driver {edit: lost that bet, the '7302 has two drivers, both driven at the same time}.
RBob.
Old Feb 15, 2005 | 01:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good possibility the dash plugs are identical (between an '85 & '88 Camaro). If not then very close. Between the dash and the ECM it will be items such as the VSS, SES light, and ? (has to be another).
RBob.
Old Dec 6, 2005 | 11:25 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Alright! The 749 is in! Car starts... isn't totally happy, but I'm pretty sure that's a spark problem.
Code:
CON == Connected as shown	NC == Not Connected	NEW == New Wire
PROV == Connected and Proven (Via Datalog or Function)
Function (Note)  (Color on 302)	        302	165	730	749
PROV	Fuel Pump Relay    (Dk Grn/Wht)	A1	A1	A11	A11
NC	A/C Clutch	       (Lt Blu)	A2			F1
NC	Evap Purge	   (Dk Grn/Yel)	A3	A3	F7	F7 ***
NC	EGR Control		  (Gry)	A4	A4	E9	E9
PROV	SES		      (Brn/Wht)	A5	A5	E7	E7
PROV	VIGN (Ignition-On)    (Pnk/Blk)	A6	A6	A6	A6
NC	TCC		      (Tan/Blk)	A7	A7	F6	F4
NC	SHIFT				A7	A7	F1	(F4?)
CON	Serial Data (ALDL E/M)    (Orn)	A8	A8	A8	A9
CON	Diagnostic (ALDL B)   (Wht/Blk)	A9	A9	E12	E12
NC	VSS Signal Input	  (Brn)	A10	A10	C6	C6
NC	MAT Signal Input (B)      (Tan)	A11	C12	F16	F16
PROV	GND (Chassis/ALDL A)  (Blk/Wht)	A12	A12	A12	A12
PROV	+12V Constant		  (Orn)	B1	B1	B1	B1
NC	Fuel Pump Signal      (Tan/Wht)	B2	B2	E13	E13 (Unused?)
CON	EST Dist. Ref Low     (Blk/Red)	B3	B3	D9	D9
CON	EST Signal Output	  (Wht)	B4	D4	C8	C8
CON	EST Dist. Ref High    (Ppl/Wht)	B5	B5	D8	D8
NC	Digital MAF Signal    (Brn/Wht)	B6	--	--	--
NC	Analog MAF Signal		--	B12	--	--
NC	???VATS					B6	F10	F10???
NC	EST Retard (Knock Sensor IN)	--	--	F9	F9
NC	A/C Request	   (Dk Grn/Wht)	B8	B8	C9	C9
NC	PSPS (power steering)	  (Gry)	B9	--		D13
NC	Park/Neutral Switch   (Orn/Blk)	B10	B10	D16	D16
NC	AIR Conv Solenoid	  (Brn)	C2	C2	F4	F4
CON	IAC "B" LO	   (Lt Grn/Blk)	C3	C3	E6	E6
CON	IAC "B" HI	   (Lt Grn/Wht)	C4	C4	E5	E5
CON	IAC "A" HI	   (Lt Blu/Wht)	C5	C5	E3	E3
CON	IAC "A" LO	   (Lt Blu/Blk)	C6	C6	E4	E4
NC	4th Gear Signal	       (Lt Blu)	C8	C8	D14	D14 (See RFCs)
NC	A/C Fan Req		  (Blu)	C9	D11
CON	Coolant Temp Input	  (Yel)	C10	C10	E16	E16
NC	TPS Back-up	       (Dk Blu)	C12	--	--	--
CON	TPS Signal (B)	       (Dk Blu)	C13	C13	F13	F13
CON	TPS +5V Reference (C)     (Gry)	C14	C14	A5	A5
PROV	BATT			  (Orn)	C16	C16	C16	C16
PROV	GND (Chassis)	      (Blk/Wht)	D1	D1	D1	D1
NC	FAN		   (Dk Grn/Wht)	D2	C1	E8	E8
NC	8CYL Hard Switch		--	D3
CON	EST Bypass	      (Tan/Blk)	D5	D5	C7	C7
CON	O2LO (GND)		  (Tan)	D6	D6	D6	E15
CON	O2HI (Signal)		  (Ppl)	D7	D7	C8	E14
NC	EGR Diag Switch		  (Wht)	D8	C15	D14	D14 (See RFCs)
NC	GND (Chassis)			D10	D10	D7	D7
NC	MAF Burn Off			--	D12	--	--
CON	GND (CTS/TPS/MAT)	  (Blk)	D13	D2	B5	B5
CON	Injector Bank A/1 (246  Lt Blu)	D14,D16	D15	C11	C11
CON	Injector Bank B/2 (135  Lt Grn)	D15,C15	D16	C10	C10
	MAF Analog Ground		--	A11	--	--
	AIR Valve Port			--	A2	F2	F2
NEW	MAP Ground (A - Blk)		--	--	B6	B6
NEW	MAP Signal (B - Lt Grn)		--	--	F15	F15
NEW	MAP +5V Reference (C - Gra)	--	--	A4	A4
NEW	'749 D5-to-D6 and C13-to-C15 Jumper Wires (Injector Sense)
IAC works as shown.
RFCs: 749 Supplemental Info / Requests for Insight:
	According to current documents, the turbo 749 does
	not employ an evap purge output on the ECU... which
	I find rather odd. I'm assuming it's really there,
	just not in the documents. It's listed as
	"unused" for the Sunbird and simply F7OUT for the
	ECU, but http://speedtoys.com/~bort62/7749/86to92.txt
	lists it as the EVAP purge. Insight?
	Pin D14 conflicts between documents as the 4th gear
	switch and EGR Vacuum Diagnostic switch. Assume
	actual purpose is software-dependant.
	So far, *all* of my conflicting information is courtesy
	http://speedtoys.com/~bort62/7749/86to92.txt ... the
	question is... who's right?
Resources:
RBob of ThirdGen.Org
http://www.cruzers.com/~ludis/1227165schematic.html
http://www.cruzers.com/~ludis/1227749schematic.html
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227749/
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227165/
ftp://ftp.diy-efi.org/uploads/SyTyWiring.zip
Old Dec 7, 2005 | 02:14 AM
83 Crossfire TA's Avatar
What, something like this:
Attached Thumbnails 1227302 to 1227165/730/749 swap-aut_8067bs.jpg
Old Dec 7, 2005 | 02:15 AM
Attached Thumbnails 1227302 to 1227165/730/749 swap-aut_8064.jpg
Old Dec 9, 2005 | 11:23 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Hah.. yanno, the sad thing is I ended up using an extra socket as a riser to make the low profile socket clear the netres anyway, so it's still almost that tall :P
Old Dec 11, 2005 | 01:21 PM
That almost fits under the stock cover as it sits, but the ZIF is just pushed into a normal push in socket that is soldered to the memcal so when I have a tune that I like I can just pop the zif out, pop the chip in, button it all up and it’s done.
Attached Thumbnails 1227302 to 1227165/730/749 swap-aut_8063.jpg
Old Dec 11, 2005 | 01:28 PM
I did have to modify the KS board to sit lower and in a slightly different position then it does from the factory to clear the big overhang on that socket, but that wasn’t a big deal really.
The whole thing was part of my 165/730/749 swap, which only really took me an hour of actual repining (and worked out of the box once I figured out that tunerpro was calculating checksums incorrectly), but that was because in the end I ignored much of what was already up out there when I found that some of the pinout on the speedtoys and linked sites didn’t actually work out right according to the factory wiring diagrams. At some point I’ll have to type those up and post them somewhere to prevent all the “I did it like it said and it won’t run/idle/whatever right…” posts.
Old Jan 4, 2006 | 02:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Hay guys I am trying to dig stuff up on the 165 to 749 ECM swap . I am a little affraid to start doing it but ... I kinda have to if I wanna get the most out of my turbo setup.
couple of questions if you don;t mind....
Thats last chart posted has the pinouts on it and I am just trying to understand it. Under the 165 heading ( just picking a random thing)
the pin on the ecm for 165 is A8 ..then to convert I would pull this wire out of the plug at that location and put it in the A9 slot ? What goes in the location I just pulled the wire out of ?
Here is another one
Acoording to the above legend ( in the document) it says NC = not connected . But would I still take the wire from the A7 location and move it to the f4 location ?
Thaxn for all the help on this . I wasn;t sure if I should have made a new post or not . This is one of them topics that start out with alot of confussion for me
thanx again
Old Jan 4, 2006 | 02:54 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Here is another one
thanx again
also . I am seeing that some pins are located to a spot that starts with an F ...I don't see that location on any of the punout locations you guys posted up ? Kinda confused here
Old Jan 9, 2006 | 02:04 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Yep. A8->A9. What goes back into the position you just removed the wire from is of no relative concern. The position may have another function, or it may have no function, but it isn't something to think about when removing the pin. (In the case of '749/A8, that would seem to be no function)
That's just the test status on my end. NC means I'm not using it and thus can't be personally 100% certain of correct function or repinning.
If you notice the picture of my adapter harness, P4 ecus have an extra connector (the yellow one, in this case). Those are the E/F rows.
Old Jan 11, 2006 | 03:31 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I appreciate the feedback . I was worried I wouldn't get any because when you reply to a sticky ...it doesn;t light up
So for the ones not conncted "NC " It is safe to just leave that location void of a wire ? Just don't want to fry anything
thanx a bunch man !
Old Oct 4, 2006 | 12:12 AM
RSFreak's Avatar
Transmission: TH700R4
For the '302 to '730 ecm swap;
Injector bank A/1 '302 at D14,D15 - '730 at C11
Do I connect both D14 and D15 to C11 on the '730 harness? (Same with bank B/2 I assume?)
EDIT: OK, after looking at my '302 schematics I have determined that D15 and C15 are jumpers so I shouldn't have to connect them to my '730 harness, right?
Old Oct 10, 2006 | 02:28 AM
RSFreak's Avatar
After checking each wire to make sure there would be no issues during my swap, I found that C10 on my '730 harness has no wire. I consulted my '730 schematic and determined that C12 is in fact the location for Injector Bank B/2, not C10 as shown above. If anyone has any info to the contrary, please post it as I am really wanting to get this swap done!
Old Jun 21, 2007 | 05:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Re: 1227302 to 1227165/730/749 swap
K , so the above two notpad documents .... they contradict eachother totally.
I am lost as to which pinout notes to use . The first one says one thing ..... the next one says totally different pinout locations .....what do I use ?
Old Jun 21, 2007 | 05:56 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
first notpad document gives these changes
165-749 swap only pins moved
A2 - disconnect
A11- C12
B4 - B12
B-6 B12
B12- B12 *
C1-C1*
C9- D11
c12-c12 *
c15-c15*
D2-C1
D4-D4*
D8-C15
D11-D11*
D12- DISCONNECT ...new wire if needed
D13-D2
D14 UNUSED-D2 ( is theere a wire there in the first place ? )
D15-D16
D16-D15
the next notpad document gives these pinout changes ..
A1 -A11
?- F1
A3-F7*** ??? what does this mean ?
A4- E9
A5- E7
A7-F4
A7- F4? <--- do I change it or not ?
A8-A9
A9-E12
A10- C6
C12- F16
B2-E13 unused ???? what does that mean ..should i hook it up ?
B3-D9
D4-C8
B5-B8
B12- -- <---- WHat does that mean ?
B6-F10
-- - F9 <---- is that a jumper ? or what comes from there ??
-- - D13 <---- agian what is there in the first place
B10 - D16
C2-F4
C3-E6
C4- E5
C5- E3
C6- E4
C8-D14 see RFC's <--- what ar ethese RFCs?
D11 - nothing posted here ..what to do ?
C10-E16
C13-F13
C14-A5
C1-E8
D3- <--- nothing posted there ?
D5-c7
D6-E15
D7-E14
C15-D14 See RFCs <--- where are these ?
D10-D7
D12- -- Where does this go?
D2-B5
D15- C11
A11- -- Where does this go?
A2-F2
-- - B6 ??????? what goes there ?
-- - F15
-- - A4 ?????? what comes from there to A-4
Old Jun 26, 2007 | 07:58 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
anyone ?
Old Oct 27, 2007 | 11:26 AM
poodu45's Avatar
My son and I did a 350 conversion on his 85 jagxjs and are putting a twin turbo setup on it-it is his first car my first try at fuel injection-I have the pin swap on my harness for the 749 ecm but have no idea on how to convert the prom to 8 cyl-is there anybody who can get me started by setting my prom to 8 cyl to get started literally-we do custom interior work maybe a trade-or can I run a stock ecm and tune with timeing and larger injectors
Old Jan 20, 2008 | 10:32 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Thought I'd provide a link for v6'ers wanting to convert to a '165. I started my swap using this info and quickly found the flaws in it. The repin's mostly correct, but missed a few critical points. Here's a more thorough guide -> https://www.thirdgen.org/forums/diy-...take-look.html
Old Aug 8, 2012 | 07:12 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I did that swap before I realized that the 749 wasn't what I wanted as it wasn't going to support a 16 injector system. I finally pulled the entire wiring harness with ECM and PROM to install an XFI DFI..
Remember some key points
165 uses MAF and ESC and a Knock Sensor
730 uses MAP and uses a 350 knock sensor.. different than the 165's
749 uses a 3 Bar Map and only a few wires are moved from the 730 setup.
For anyone doing this conversion.. Since the 165 only has 2 plugs going into the ECM, I would label each wire with tape on every wire before removing them from the plug. The 730 uses 3 plugs and all the wires from the 2 plug system have to be transferred.. The only difference on the 749 was IACV , the TCC, ALDL and a couple of other wires.. I don't remember which ones.. If I wasn't in Afghanistan, I would upload my entire book that I used for the full conversion.
If you aren't planning on boosting your engine with a turbo or super charging it, it isn't worth the swap to do the 749.. That is what the cyclone, typoon and the Grand National and turbo Sunbird cars used.. You can still use the 730 with a boosted application.. You can use the AUJP on either ECM. If you use a boosted application I would definately use the $59 from code59.net.. Remember that you will have to use C.A.T.S. or tunerpro and shut off the VATS in the programming, and then have fun with the tuning.. You engine is almost guarenteed to run like crap until you tune it.
Old Sep 8, 2014 | 11:38 AM
Tri'all's Avatar
Car: would like to drive this 1987 iroc
Engine: 5.7 bored .030 over
this seems interested if i could open some attachments Im looking in electrical with my car right now
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
