what is the proper way to check injectors?
Old Dec 18, 2004 | 03:50 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
my 90 firebird 3.1 is giving rich exaust errors. How can I check the injectors? resistance at the clip or something. I have an ohmmeter. Also what is the stock # for the injectors on this car. The ones at the Auto parts store are like 80$ EACH. I want to buy some accels or maybe ??
thanks
Old Dec 18, 2004 | 04:17 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
There is a resistance test for the injectors, although I'm not sure what it is off-hand. You can also do a pressure check. With ignition on, engine off, and a fuel pressure gauge connected, you should get about 43 psi... this pressure should hold (although for how long no one knows). And if the pressure does not hold, this does not necessarily mean the injectors are leaking. It could be a check valve or something.
A popular option (which I went with) is to send your injectors to be professionally cleaned (try www.cruzinperformance.com).
Old Dec 18, 2004 | 04:33 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
i just replaced all my injectors with remanufactured ones, they were 69$ canadain each and i got 60$ core for returning the old ones. i also got a dealer discount
jklein337
Sep 19, 2018 06:23 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
beast94
Aug 20, 2015 06:44 AM
