Turbo 2.8L v6???
Old Dec 24, 2004 | 08:21 PM
Erik_Fahlman's Avatar
Car: 1988 Camaro
Engine: 2.8L
Transmission: Th200
Turbo 2.8L v6???
New to the site and lookin for info about Turboin my 2.8l??
Old Dec 24, 2004 | 08:55 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
do a search, been discussed many times and is being down by a few people. doward is one off the top of my head, others are as well.
Old Dec 24, 2004 | 10:13 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
There is a kit available. COntact Doward for details, great performance boost for your dollar.
Old Dec 24, 2004 | 10:26 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
You can also check the 'poweradder' board for more information.
Mostly 8 cyl stuff there put does have some for 6.
Old Dec 24, 2004 | 11:27 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Kits go on sale mid February. Everyone wants me to wait until Tax Return Season
But yes, if you have any questions, feel free to ask!
Old Dec 25, 2004 | 03:17 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
ah glad to see you found the site eric
just search under turbo and you'll see the results
Old Dec 26, 2004 | 07:30 PM
V6camaroman's Avatar
what do the kits cost doward? u still guarantee 100hp right? i could still never understand why mine ran so slow. best i got out of ti was a 17.17 at 78 mph
Old Dec 26, 2004 | 07:34 PM
Doward's Avatar
The kits are going to run about $2900, plus shipping (depends on where you are, lol!)
Yes, the kits will increase your hp +100 over stock, as long as you have a well tuned, good running car. I went from 140hp @ the flywheel, to 255hp. And the kits will include a slightly bigger turbo, for slightly more power
Old Dec 30, 2004 | 06:39 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
we cannot stress enough that the engine must be in good condition.. the turbo doesnt hurt it, its just if someone with 190K on their engine puts a turbo on, and cranks it to 20 psi, you know they're gonna come at us with a complaint.. the kits are the product of MANY days/nights/long beerless weekends of R&D and we've pulled things off a couple of times to replace it with something better.. (metal for rubber, better bends, etc) we can break down an entire inventory list if need be. dyno and soon real track (with traction) times will show how effective these huffers can be.
Old Dec 31, 2004 | 09:32 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
100 hp is a TREMENDOUS power increase, giving a baseline of only 135-140...... Christ....
You guys rock. These V6's are gonna be pulling on 5.0's now... I hope you guys make this big! I'd love to see a bunch of little turbo sixers running around.
Hell, I might just buy me another 3.1....
Old Dec 31, 2004 | 10:34 AM
Doward's Avatar
LOL, kidding!
Oh yeah, just scored a '730 + pigtail.
No worries. The 3.1 guys won't be left in teh dark.
Old Dec 31, 2004 | 11:50 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Yeah,thats what I was going to ask
Is it only for the 2.8?
How much does it cost to install?
Old Dec 31, 2004 | 12:07 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
5.0's
They be taking on 350's!
Old Dec 31, 2004 | 01:01 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
and beating em too
Old Dec 31, 2004 | 01:12 PM
Doward's Avatar
Already proved that, too Took down a '88 GTA 350 TPI at the track, with a bad launch!
The kits WILL be available for the 3.1s, as well!
How much to install them? Depends on where you are, and what kind of rates shops charge you. I honestly couldn't say.
Old Dec 31, 2004 | 01:24 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
What exactly comes with it?
Turbo
Intercooler
Wastgates etc.....
Old Dec 31, 2004 | 01:27 PM
Doward's Avatar
Turbo
Intercooler
Wastegate
BOV (another point for the '730 swap - you can use one that vents to atmosphere, for that PSSHH sound we all love)
all exhaust piping (Y pipe to turbo)
all intercooler piping
30pph injectors
new ECU reprogrammed for BOOST!!!
Depending on how it all ends up, in my own MAF vs MAP debate, either a new MAF, or a new 2 bar MAP sensor.
Pretty much everything I can think of, to make this a bolt-n-go system.
Old Dec 31, 2004 | 02:02 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
hmm...So these kits will work with stock exhaust/intake/cooling system and transmissions?
Old Dec 31, 2004 | 06:12 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Intake will be ground-up replaced regardless due to turbocharger and intercooler placement. Probably using a cone filter.
For optimal power gains you'll want to pick up a good flowing mandrel bent 2.5"-3" from wherever Doward's piping ends on back. Ditch the stock crossflow muffler, need something open. High flow cat will help, though durability is debatable (question for the exhaust board as to which stand up best). This is optional, but without decent exhaust, your experiences may vary from those who do have a good open exhaust.
Cooling system should be just fine, but if you want to play it safe I'd reccomend going with a 180 degree thermostat (high-flow if available) or drilling a small hole or two in the stock 195 (drilling will cause warm-ups to take longer, but consider that you're getting extra heat from cooling the turbo, so warm-ups might be faster anyway. the hole will help keep water moving and decrease the probability of hot-spots developing). Again, optional. For durability's sake, since under boost you'll be applying alot of extra heat to the system, it's a good idea, but I doubt Doward or I have done a whole lot to our cooling systems, and you don't see us complaining... yet...
Transmissions: Doward's WC-T5 appears to be holding up nicely (although his first clutch didn't). My T5 (circa '84) is not holding up as nicely, but it hasn't snapped in half (yet) and I don't think it's had a rebuild in its life, so most blame goes to lack of maintainence (and I'm not sure I even want to look at the clutch). Pre-88 700R4... if you're not religious, pick one before installing the kit. 88-up 700R4, probably be okay longer than the Pre-88 and should leave you with a few months to pick the religion that's right for you.
Old Dec 31, 2004 | 06:39 PM
Nixon1's Avatar
5.0's
For what it matters, I meant 5.0 Fords. Or GM 350's (to exclude the LS1 and some LT1's)...they perform about equally when it all boils down...
Either way, this is going to be a BIG step for all 3rd gen owners.
Old Dec 31, 2004 | 08:53 PM
Doward's Avatar
First clutch had 120k miles on it!
Also just like to point out I have 7 girls, 3 guys here at my party (not including me!).
No sausage fest at Doward's place! Happy new year guys!!!
Old Jan 1, 2005 | 04:11 PM
Nixon1's Avatar
Haha, nice..happy new year to you too bro. Unfortunately I drank some bad liquor earlier that night so I had to quit drinking cause I got real sick... NEVER BUY PRE-MIXED DRINKS! *** damn Chi Chi's White Russian mix......
Old Jan 1, 2005 | 04:19 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
dowards gunna be sleepin in $$$$
Old Jan 1, 2005 | 09:41 PM
Doward's Avatar
Actually, I won't... I'm not planning on making any real money off this!
I'm doing this for the V6 community!
Old Jan 2, 2005 | 12:27 AM
oil pan 4's Avatar
Car: 89 Firebird
the dude said it like this:
"Actually, I won't... I'm not planning on making any real money off this!
I'm doing this for the V6 community!"
I get the same story trying to crank out Titanium chasse parts.
But they will be for All 3rd gens and most 4th gens.
I'm most likely going to make one or 2 at a time at first and announce it on the bords and put them on ebay and let people fight over them that way.
After I expand the operation, buy more tools and buy more Titanium for a bigger in house stock of with more choices There won't be much $ left over.
I think I found some non automotive appications where Can make more $$ per pound of titanium.
Buying Titanium welding wire for $150 per pound is the biggest buzz killer so far.
Old Jan 2, 2005 | 08:48 AM
Doward's Avatar
At least Ti is light... but $150/lbs is still wicked crazy!!
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
bplessy
Sep 30, 2015 12:14 PM
