How much are u getting
Old Jan 4, 2005 | 06:06 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
Today i measure up my MPG and found out that i am getting about
16.74 city traffic.Is that normal and how much gallons is our fuel
tanks.
Old Jan 4, 2005 | 06:10 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i get around 17-18 in the city...my highway is like around high 20s....
edit: i just got 18.54 all city driving!
Old Jan 4, 2005 | 06:13 PM
7plagues's Avatar
i believe we have 15 gallon fuel tanks?or 15.5?
Old Jan 4, 2005 | 06:41 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I think they're 15gallon tanks and I get about 140 - 160miles per TANK not even city driving, kinda in between....cruisin at 40 mostly. Horrible gas milage.
Old Jan 4, 2005 | 06:42 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i get about 15.5 driving it rough in the city and about 26 highway even with 3.73 rear end and all of the motor mods. we have 15.5 gallon tanks.
Old Jan 4, 2005 | 06:43 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
15miles tank I'm pretty sure. I get 140 - 160 miles per TANK doin mostly 40mph cruisin more then anything. Horrible gas milage, considerable idling though...about 40mins a day worth 5 days a week.
Old Jan 4, 2005 | 06:53 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Then i think i am getting a good one since i drive only 4 miles on a highway and the rest is a horrible traffic doing about 25mph or less. Also found out at 1AAuto is selling a fuel tank for our cars that is 14 gallons. Is their tanks smaller?
Old Jan 4, 2005 | 07:14 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
my car gets almost all city driving. Over the summer I get about 17-18'ish.
winter, letting it idle and engine never gets full operating temp. I get about 15.
My car has gotten 28 on highway, and once it claims to have gotten 31.6 I wont belive that tell it does it again.
Old Jan 4, 2005 | 07:44 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I'm getting 17-19 mpg. Mostly short drives. It is only 8.5 miles one way to work, stores are about 10 miles away. Barely long enough for the thermostat to open once. I fill up at about 1/4 tank, takes 11-12 gallons, so it has to be a 15.5 gallon tank.
I also can't seem to keep my foot out of it.
Old Jan 4, 2005 | 08:04 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I get just over 300 per tank, and that's TURBOCHARGED!!
Old Jan 4, 2005 | 08:12 PM
7plagues's Avatar
just another reason to buy your turbo right?
jeez thats good...i get around 230-250 a tank
Old Jan 4, 2005 | 08:16 PM
Dale's Avatar
Engine: 350 S-TPI
my guage is f-uped, so I fill up at 200 miles no mater what!
Old Jan 4, 2005 | 08:40 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Dale it's a Chevy! My gauge reads 1/4 when it's empty and over full when it's full. The speedo doesn't start to read until you drive a mile or two.
As far as mileage the best I have recorded is 26.5- but I am sure at 203,000 miles the injectors are not what they should be.
I'm sure if a trip was made in cooler weather without the A/C blasting, a passenger and suitcases and cruise control (that we don't have) locked at 70 we would do better.
Old Jan 4, 2005 | 11:07 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Mine gets 17-19 city and about 25 highway. Fuel tank capacity for our cars is 14 gallons, but you can squeeze a little more than that in I imagine.
Old Jan 5, 2005 | 04:13 AM
bru333's Avatar
Car: 1987 Camaro SC
Where did you get 14 gallons from? GM service manual for '87 only lists a 15.5 (fuel injection) and a 16.2 (carb) gallon tank.
There were several diff. size tanks between years, and options. From 12 gallons up to 16.2...
https://www.thirdgen.org/techbb2/sho...l+tank+gallons
Old Jan 5, 2005 | 04:53 AM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
i saw a 14 gallons tank at the 1aauto website
http://www.1aauto.com/1A/GasTanks/Ch.../GM2721B/8627.
It says 82-92.Could They be wrong because every time i go to the gas station my car gets only 11 or 12 gallons. It with the neddle al the way down.
Old Jan 5, 2005 | 05:39 AM
bru333's Avatar
Car: 1987 Camaro SC
This is another one of those subjects that everyone has a different answer for. There are several reasons why our cars will take different amounts of fuel.
Several different size gas tanks were used, depending on year and options.
The gas gauge is not the most accurate.
You can't get all the fuel out of the tank with the fuel pump.
Gas pumps shut off when the foam reaches the nozzle, not liquid, so you can usually squeeze .5 to 2 gallons more in
Old Jan 5, 2005 | 10:07 AM
confucius101's Avatar
ok so if you avarage this out to
150 mpg the cut into that by 15
your only getting around 10mpg?????
what problems are you having
if any with your car?????
sorry but you just seem to be about 6 under everone else!!
Old Jan 5, 2005 | 11:12 AM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
My cat was plugged. I acquired a test pipe. I average 20mpg. My best is 27 hwy. If I had my injectors redone by Rich, would I see gains in mileage, and if so why?
Old Jan 5, 2005 | 12:28 PM
bru333's Avatar
Car: 1987 Camaro SC
If your injectors are leaking because they are dirty (like mine were) then cleaning them would keep them from wasting gas. Better spray pattern = better air fuel mix= more efficient combustion.
Old Jan 5, 2005 | 01:23 PM
Doward's Avatar
Yes, I knocked down about 26 mpg, pre turbocharged, and with new, clean injectors.
Now I'm doing more like 22-23 mpg average.
Old Jan 5, 2005 | 03:17 PM
Car: 91 Camaro
i think that he means that he only dropped like 3-4 mpg with the cleaned injectors AND turbo! that's really not too bad!
Old Jan 5, 2005 | 03:21 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
If its all highway i get about 30 MPG When i have city/hwy i get about 20 and if its all city about 15.
Old Jan 5, 2005 | 04:41 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
If i get all highway my average is 23 but city is 16.7. For what i have seen here is pretty good.
