Removing the distributor
Old Jan 9, 2005 | 09:36 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
OK, it seems like this should be simple but i have no idea how to do it. Im changing out the o ring and i have the cap off and everything but i cant even see how its being anchored in. please lemme know how how this is supposed to come out. THANKS.
Old Jan 9, 2005 | 10:26 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
If you look just to the passanger side of the distributor, feel down the shaft - you'll feel a bolt, with a small distributor clamp - it's a 15mm bolt - remove it, and then you can just pull the distributor out!
Old Jan 9, 2005 | 10:30 PM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
There is a clamp with 1 bolt bolted to the engine block if I remember correctly. Make sure you mark the distributer by drawing a line with chalk from the tower to the block so you can put it back in exactly where it was otherwise your timeing will be way off and the car wont start.
Old Jan 10, 2005 | 06:18 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
And make sure you also mark the rotor placement compared to the distributor. If the rotor (or distributor) doesn't go on in the same position as you take it off, the car won't run. It probably wouldn't be a bad idea to get a timing light always to make sure everything is correct.
Old Jan 10, 2005 | 10:53 AM
mvftw's Avatar
To make life EZ, get a 15mm swivel socket.
Old Jan 10, 2005 | 10:51 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
i have an extention and a swivil and a 15 mm socket and i cant get the socket on the bolt, is there any special trick or anything?
Old Jan 10, 2005 | 11:51 PM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
haha alrighty got it out........no o-ring even on there. sweet.
Old Jan 11, 2005 | 12:10 AM
3.1RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI
Ok so now i dont know where the oring is supposed to be.....if anyone has a picture of the distributor with the oring on there that would be great!
Old Jan 11, 2005 | 08:24 AM
mvftw's Avatar
I said was a 15mm swivel scoket, not a swivel and a scoket.
http://www.sears.com/sr/javasr/produ...id=00943206000
Old Jan 11, 2005 | 12:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I bet you've got an o-ring; and I bet it doesn't look like an o-ring anymore, that's why you're not seeing it.
Look for a black piece of hard plastic between two lands (bumps on distributor shaft). The edges will look square, they won't look round like an o-ring. Take a screwdriver to it and snap it in half.
Then take the busted hard-as-plastic one, and bend it backwards. You'll see a million little cracks- the cause of the oil leak.
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
