Wheel Bearing ?'s
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
Wheel Bearing ?'s
I have been hearing the start of and the growing loudness of a squeel coming from the drivers side front wheel of my car. I believe that it is one of the wheel bearings going bad. The question I have is which one commonly goes bad on these cars, the inner or the outer bearing. I was just wanting to know so I can figure on which one I am going to need when I get around to replacing it?
Car: IROC Z
Engine: 5.7
both are very cheap and easy to fix. wheel bearings are 20$ for all of them, you need the gasket too. get some synthetic wheel bearing grease, pack it and slop it all in there and youll be fine.
Car: 2000 Trans Am WS6 (Black)
autozone sells them for $3 a peice, or the $10 version(I got that because the cheap one didn't last long)... it may have something to do with the fact that somehow my car didn't have the SEALS!! wtf... the guy before me didn't have them, so when I did the brakes I didn't even think of it... but I just redid my brakes again... got like $200 for everything... both new rotors, ceramic pads, grease, seals, and bearings.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
The AZ valuecraps are a pure POS go with there timkin good quality. Do both inner and outter. I paid 300 to redo my brakes with all new bearings seals calipers slitted rotors pads and new brake hoses. Stops like a champ now
Car: 1986 Firebird
Engine: 2.8 V6
Whenever I change my front pads, I always re-pack the wheel bearings. I've never "just" changed the pads. I moved to full synthetic grease about 5 years ago, too.
I haven't had to change my brakes in about 2 years tho... and I'm kinda looking forward to it- I got one of those bearing greasers that hooks up to a grease gun! No more re-packing by hand! And I've got the air-powered grease gun, too- that should be fun!
Car: check
Engine: check
Transmission: check
Re: Wheel Bearing ?'s
RBob.
while we're on the topic... cheaper pads have that stupid "squealer" set at about half pad-wear... you should always move it.... plus I always purchase Adhesive-style pads, to keep that damned rivet from destroying my rotors...
Car: 91 Firebird
Engine: 191ci 6cyl
When replacing or repacking the wheel bearing how tight do you wanna go with the nut? Really friggin tight or tight enough so there's no wiggle but the wheel spins freely?
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
12 ft lbs while spinning the rotor forward by hand (tighten to 12, and continue tightening as neccessary while you spin), then back the nut off until it's just loose enough to turn by hand, snug down by hand, insert cotter pin. If cotter pin doesn't line up, back off nut slightly until it does.
Leaving the bearings tightened to 12 ft-lbs and driving on them would cook your bearings in short order.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
rudolphschenker
Sep 4, 2015 02:41 AM
