T-5 in a 3.1
Old Jan 13, 2005 | 08:35 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
T-5 in a 3.1
I am looking at buying a conversion plate to convert the bolt pattern to a 350. I want to with a T-5 trans or T-56 if I get some money. Has anybody ever dropped one in there V6. I am working towards the V8 so I am taking 1 step at a time
Old Jan 13, 2005 | 10:38 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
T5 will not stand up behind a stout V8, without some serious work (look into the GForce T5 kit) - even then, you have to worry about the tranny case flexing.
T56 is a sure bet. I'd recommend just putting it in, at the same time you do the V8.
Old Jan 15, 2005 | 02:23 AM
ThUnDeR2005's Avatar
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Doward is right, I was reading a few days ago about T-5s. This guy who made a site about his camaro projects had used the t5 to 350 camaro kit. 3 times. Burned out the t5 2 times in a row and the 3rd one just broke. Hes goin with a t56 swap. I'd recommend doing the same thing
Old Jan 15, 2005 | 09:43 AM
nsimmons's Avatar
My t5 is fine, with the only problem being a dying second gear syncro, which was a problem before i built the engine. Honestly its probably just the gear oil in it, i should be running atf but i havent had time to change it.
Texas lt1 has a t5, if you follow his posts he beats the snot out of it and it lives.
This is a kid with a 3.1 odds are he's not going to be building a 383 and flogging it at the track weekly.
Old Jan 16, 2005 | 05:05 PM
BitchinRS's Avatar
I all ways find it kinda funny that pepole say the T5 can't handle a V8. Depending upon the year the Iroc Z's and Z28 had an option of a T5 or automatic. If it couldn't handle a V8 why would it have been an option? Surely GM wouldn't put the self in the position of having to replace a tranny a bunch of times while it was under waranty!
Old Jan 16, 2005 | 05:41 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
The T5 was not offered with the L98. If you wanted a T5, you got a 305. Go check with the "History/Restoration" board on this one.
Basically, a T5 will hold up under some power as long as you don't do dragstrip clutch dumps with slicks (or street tires for that matter) and full on sidestep the clutch with the throttle to the floor powershifts. Sure, there are some freaks out there that abused the hell out of their T5 and had it live, but not most.
I knew a kid who in '91 had the identical el-strippo Iron Duke powered S10 as I did. My T5 was still going strong at 157,000 on the original clutch when the engine holed a piston and I pulled the works for a V8/700R4 swap.
He destroyed two T5's and one rearend within the 36,000 mile warranty by doing things such as getting it going about 25 mph in reverse, then shoving in the clutch and grinding it into first while it was still coasting backwards, redlining the throttle and dumping the clutch to do burnouts.
Old Jan 18, 2005 | 01:13 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
backing it up and dumping it is for front wheel drives
Old Jan 18, 2005 | 02:43 PM
Rexer's Avatar
Car: 92 firebird
Engine: 3.1 V6
Transmission: 5 speed manual
Axle/Gears: t5 and standary rear end
how about....
doing 25 mph forward and then whacking it in reverse ? lol
Elephantismo
Feb 13, 2019 12:51 AM
luvofjah
Sep 26, 2015 08:28 PM
cking99
Sep 22, 2015 11:33 AM
DARKmj16
Sep 9, 2015 04:07 PM
