Msd
Old Feb 18, 2005 | 09:15 AM
TVRPAUL's Avatar
Engine: 3.4lL 60* V6
Transmission: Tremic TKO 600 RR
Msd
Building 3.4 crate engine, with holley 390 4brl. Mallory dist. headers, staying with cam that comes with engine. Now is there any good reason to put MSD.
Thx
Paul
Old Feb 18, 2005 | 11:58 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
it made my 3.4 run better after the self bbq. That good 'nough reason?
Old Feb 18, 2005 | 03:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you're ditching the computer, it makes sense to add one on while you're at it. Could always go with a Mallory box, too.
But if you were keeping the computer and the fuel injection, I'd say it wouldn't be worth it and to just add a high-output spark coil. I didn't notice any difference on my fuel injected '86 when I put an MSD 6AL box on.
Old Feb 18, 2005 | 04:21 PM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
Yeah especialy if you are going carbed. Not only for performance but for cold weather starts. Before I put on the msd I usaully had to keep pumping the gas to start it and rev it to warm it up but after I installed the msd with a high output coil It always started on the first crank and would keep going without stalling. But make sure you adjust your gap on your spark plugs and mount the box away from any direct heat.
Old Feb 18, 2005 | 10:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A better Ign system is allways better over stock parts.
Its one of the first mods that should be done.
Old Feb 18, 2005 | 10:12 PM
TVRPAUL's Avatar
Responce to all MSD
I am putting in a Mallory Uniliteelectronic distributor
Old Feb 18, 2005 | 11:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Responce to all MSD
I really have no clue so....
Is that a cap n rotor type or a trigger system???
Long as you have good control over timing advance and the curve your good to go.
Old Feb 19, 2005 | 07:30 AM
TVRPAUL's Avatar
MSD
The Mallory Unlite distributor that I am putting on the 3.4 is an electronic ignition with a self contained optical pickup & module.
The engine will have the 390 Holley Carb, and not fuel injection
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
