msd coil problem
Old Mar 5, 2005 | 08:08 AM
lov1855's Avatar
Car: 84 camaro
Engine: 2.8 v6-carbed
Transmission: th700r4
msd coil problem
hey this is my first post but have been around for a while i have a 84 2.8 camaro sport coupe and i recently bought a msd blaster stock replacment coil and when i went to put it in the other day the plugs on my stock one were completely different it seemed.is this cause mine is carbed or what? also what one do i need to get to do this upgrade
Old Mar 5, 2005 | 06:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
very well could be because your a carb engine. Honestly, most the information on this board is for the injected engines.
Where-ever you got it from should have a proper listing for that car. Or an easy conversion one should beable to be done.
Old Mar 5, 2005 | 08:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Welcome to the forum! Isn't your spark coil in the distributor cap? Check out http://www.msdignition.com for the part # you'd need; MSD makes a spark coil for the coil-in-cap style. It hooks up with two wires.
Old Mar 5, 2005 | 08:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well since I'm in a good mood I did it for ya, this should be the one you need:
http://store.summitracing.com/defaul...art=MSD%2D8225
MSD # 8225, $75. (WOW.. were these models always so expensive? Jegs has the same price!)
If you want a cheaper priced coil, looks like Accel's #140003 is $50.
http://store.summitracing.com/defaul...t=ACC%2D140003
Old Mar 6, 2005 | 08:32 AM
lov1855's Avatar
Car: 84 camaro
thanks tomp but unfurtunatly mine is not in the cap it is mounted just below the air managment valve on the passenger side of the engine. the msd coil has the female end of the plug on it were as the stock one has more of male end on it. im going to also try to get some info from msd on the topic.
Old Mar 7, 2005 | 07:27 PM
lov1855's Avatar
Car: 84 camaro
can someone please help me with this
Old Mar 9, 2005 | 02:45 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Take it back and tell them it is the wrong one.
Old Mar 9, 2005 | 08:02 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
You may need this harness. http://www.msdignition.com/pdf/8226_frm22863.pdf
Old Mar 10, 2005 | 05:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No kidding! I thought the 82-84's were coil in cap- but I never actually looked! Any way you can get a picture of yours and put it up here? Let us know what MSD says...
stalkier
Dec 6, 2015 11:25 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
