SLP Cold Air Induction Package
Old Mar 27, 2005 | 05:25 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
http://www.lmperformance.com/5548/7.html
It says for TPI Engines only,Would it work on a MPFI V6 since its like the same thing?
Same question goes with these Intake Runners.
http://www.lmperformance.com/5550/7.html
And this Throttle Body
http://www.lmperformance.com/2017/7.html
Old Mar 27, 2005 | 05:36 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ok, the tb wouldnt work. Completely different. Waay too wide. The runners wouldnt work either, as they are designed completely differently. Those are for a v8. That is why they have 8 tubes.
The cold air package would probably work but you would need to modify the part that connects to the tb.
Old Mar 27, 2005 | 06:09 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Why? It just connects to the stock accordian hose and that connects to the throttle body.
Old Mar 27, 2005 | 06:56 PM
305q_ta86's Avatar
Transmission: 5 spd
Oh ok my bad. I thought this was the one that connected right to the TB. Though it's a little tough to tell in those pics. If I were you, I would just make it from scratch though.
Old Mar 27, 2005 | 07:06 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Is the IAT located in the same place on the MPFI as on the TPI?
Old Mar 27, 2005 | 07:12 PM
305q_ta86's Avatar
Transmission: 5 spd
It is on the MAF cars.. Dont know about the MAP ones..
Old Mar 27, 2005 | 07:20 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Oh yeah,The TPI were MAF'd right
Old Mar 27, 2005 | 07:45 PM
305q_ta86's Avatar
Transmission: 5 spd
The early ones.
Old Mar 27, 2005 | 07:48 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
The early ones.
I think this will work then.its for 90-92.
Old Mar 28, 2005 | 08:08 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
What do you call the "early ones"? My friends 89 IROC is MAF I think, unless MAP looks teh same... But his IAT is in his TB, not on the intake
Old Mar 28, 2005 | 11:23 AM
305q_ta86's Avatar
Transmission: 5 spd
Is the kit not for Firebirds only?
Old Mar 28, 2005 | 01:29 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
just build your own, it'll cost like 10% of what that thing will cost and accomplish the same thing. It's real easy, just get pipe and run it from the throttle body to the area where the filter sits, get a cone filter and make it attach. Make sure each connection is air tight and your golden. I'm pretty slow and inadept at this stuff and I could do it.
Old Mar 28, 2005 | 01:33 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Yeah,I would do that but im worried about where and how the IAT would be fitted.
Old Mar 28, 2005 | 02:18 PM
305q_ta86's Avatar
Transmission: 5 spd
Dont worry about the IAT. Most people just zip-tie it to somewhere near the filter. That's what I did. No problems. If you REALLY want to, just drill a hole in it and screw it in.
Old Mar 28, 2005 | 09:17 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
IAT is the sensor in the side of the canister on the stock air filter can? I took that and ran line so it could be zip tied under the nose in front of the radiator...someone had said that you want it near cold air.....
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
