Engine mount broken
Old Apr 12, 2005 | 02:38 PM
wpaskar's Avatar
Car: 1985 2.8L V6 Camaro
Engine: 2.8L V6 multiport
Transmission: 4-speed automatic
Engine mount broken
One of my engine mounts is busted, I beleive it is the left one. Two questions:
1. How serious a problem is this? My engine rocks around a bit enough to shake the car on harder accels...which i now try to avoid...
2. how expensive/hard is it to replace such an item?
Old Apr 12, 2005 | 03:57 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I think the mount is like $15.. but it's a PITA to replace!!
Old Apr 12, 2005 | 11:47 PM
KED85's Avatar
Yeah it does suck
I waited until I swapped engines to do that job.
It can be done but really bad spot to stick hand and wrench on the thing.
Old Apr 14, 2005 | 09:29 AM
wpaskar's Avatar
What I want to know is, am I gunna die? I mean, how dangerous is it drive around with one of these bad boys broken, and the engine leaping around a bit?
Old Apr 14, 2005 | 10:02 AM
KED85's Avatar
IF you are that concerned spend the time & money to get an "EXPERT OPINION LOOKING AT YOUR CAR INFRONT OF THEM".
You know that's the safest answer anyone can offer you.
I never had abit of trouble with my broken mount on my S-10 due to lack of power generated by motor for twisting.
My frame mount died due to oil leakage & previous owner accident. I got one from the 1995 F Body engine I installed. Fit perfect. Mated to older style egine mount perfectly. I waited until I swapped engine to do my replacment mission.
Old Apr 14, 2005 | 11:55 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
first of all, which half is bad? I've seen both halfs broken, but not on same ride.
If its the rubber part, driving like a "grand ma" you can make it last a month or more I bet. If its the formed metal end, fix very soon.
I replaced the right one on my car not long after getting it. It was cheap, but took a few hours, some odd tools, and my trusty cussword book.
Just remember, every mile you drive, your taking a risk of breaking something else. Could be a cheap simple fix, or could be multi part, costly fix.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
Elliswon
Aug 10, 2015 12:33 PM
