Timing problem...
Old Apr 16, 2005 | 09:03 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Timing problem...
I went to check the timing on my car today. Hooked up the timing light and turned on car. The reading was at 10 degrees. This is BEFORE i disconnected the EST wire. With the wire disconnected the reading stayed the same. I swear last time I checked my timing it was in the low 20 degrees before unhooking the wire. What did i miss here?
Old Apr 16, 2005 | 10:13 PM
KED85's Avatar
Why was checking timing necessary?
Old Apr 17, 2005 | 12:54 AM
sixbanger's Avatar
because car is running like sheit
Old Apr 17, 2005 | 06:48 AM
KED85's Avatar
Unless the toothfairy changed something, start with the basics. Tune-up!
Old Apr 20, 2005 | 07:28 PM
sixbanger's Avatar
Plugs are new, injectors are new, fpr is new, like I said, timing is not changing even when the wire is disconnected.
Old Apr 20, 2005 | 07:50 PM
KED85's Avatar
IF then, the car performs well, I BELIEVE no true need to worry!
Old Apr 20, 2005 | 09:33 PM
sixbanger's Avatar
but the car is NOT performing well. Feels very sluggish. The cat is not plugged but it feels sluggish
Old Apr 21, 2005 | 05:21 AM
KED85's Avatar
Don't laugh at this
My Cat broke up & blocked my MUFFLER AT THE ENTERANCE. IT travelled down the intermediate pipe to the muffler neck in beginning. I replaced muffler. Still not replaced the Cat, yet.
How was this discovered?
Replaced muffler & there was the Cat Convertor. All of it blocking muffler flow! ONLY WAY THIS WAS KNOWN WAS TO DROP MUFFLER.
HOPE THIS IS A CLUE!
Yes, I did regain good amount of pep after this mission!
Old Apr 21, 2005 | 07:54 AM
sixbanger's Avatar
Already had the muffler off to replace the exhaust pipe before muffler and after cat. Cat was not broken.
Old Apr 21, 2005 | 07:59 AM
KED85's Avatar
Have you checked how much slack in timing chain?
17mm socket on crank bolt, pop off distb. cap, move the crank (using breaker bar) and see how much balancer movement necessary to move the rotor.
Beyond that you do have an old engine and it could be that time.
What are the running temps?
If consistantly high, it could be that time.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
