Swapped to 3.4, helpful hints for anyone attempting
Old Apr 20, 2005 | 06:54 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Hello,
I finally got back from my tour in Kuwait and spent 3 weeks rebuilding my '91 RS. In the process I decided to swap to a 3.4 because the 3.1 was dead. I would have gotten the 3.8, but I was doing it myself and I had a 3 week deadline so I could drive it to work.
So I got an engine from a '93 Camaro 5speed, mine's an automatic. Here are some issues I ran into along the way:
Motor mounts:
switching the motor mounts appears easy. It is, sort of. You have to move the sensor on the right side of the block so it doesn't interfere with the 3.1 motor mount. Even with that moved, the top of the 3.1 mount hits a bump that's cast into the 3.4 block. I was able to torque the motor mount bolts and got it close, but it still sits at a slight angle. When I pu the motor in, I put in the left side mount pin first, then pulled on the tranny to get the right side to line up. After both pins are in, the rubber bushing allows the motor to sit right even though the mount is slightly off.
Distributor:
The 3.4 doesn't have a distributor. I had to pull the plug and install a new one (old 3.1 dist. was gross). The important thing here is making sure the timing is right.
Exhaust manifolds:
The 3.4 manifolds would have lined up, but I didn't want an oxygen sensor in each manifold just sitting there, so I switched to the 3.1 manifolds.
Intake:
Pretty straight forward, use the 3.4 injectors with the 3.1 fuel rail and intake. I had to switch out a sensor to get the right type of electrical connector
Oil pan:
Not a big deal
Torque converter:
Since the 3.4 was a manual, I had to chisel out a brass fitting in the end of the crank for the torque converter to slide on.
Everything else on the 3.4 was left there. The balancer, crank pully, water pump, oil pump, etc. The water pump return was 1 size smaller than on the 3.1, but I was able to use the 3.1 hose with 2 hose clamps and I haven't had any problems.
There were 2 or 3 sensors that don't connect to anything because my car doesn't have those connections. It still runs good. I had to get the idle adjusted with a scan tool, and that's about it.
Let me know if anyone has any other questions!
Old Apr 20, 2005 | 07:22 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
so, your 3.4 looks kinda like mine did?
http://memimage.cardomain.net/member...0_210_full.jpg
Good work & welcome back
Old Apr 20, 2005 | 08:58 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I didnt have a problem with the motor mounts???
Other then that, sounds close. Welcome to the L32 club
Old Apr 20, 2005 | 11:09 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
Yea motor mounts should have been no problem at all.
Old Apr 21, 2005 | 09:57 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Motor mounts
Maybe there are some different block castings out there? I don't know, there was a little lump that stuck out about 1/2" from the side of the block on mine.
Old Apr 21, 2005 | 10:52 AM
Engine: 5.7 / 7.4
engine herpes? I didn't have any prob, neither did Dale as it was the same engine , but it was a 94 3.4. Maybe casting changed????????
give us a pic of the infected area
Old Apr 21, 2005 | 11:16 AM
KED85's Avatar
Thanks for the additional information for a 3.1 upgraded to a 3.4.
I had no trouble with motor mounts.
I also used the 4th Gen V6 FRAME MOUNTS connected to my ORIGINAL VEHICLE ENGINE MOUNTS.
Beyond that yep every swap will be slightly different.
I have left my 3.4 manifolds as is due to why not? They don't leak with the Oxy Sensors.
Glad you safely returned to your home.
Old Apr 21, 2005 | 11:55 AM
Dale's Avatar
Engine: 350 S-TPI
My 94 bird engine that I put in the s10 didnt have problems either.
Either way it goes, he figured something out and hes running.
midge54
Sep 2, 2020 07:13 PM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
92projectcamaro
Aug 6, 2015 01:20 PM
