clicking sound
Old Apr 21, 2005 | 10:04 AM
wpaskar's Avatar
Car: 1985 2.8L V6 Camaro
Engine: 2.8L V6 multiport
Transmission: 4-speed automatic
clicking sound
My engine has always has a clicking sound, and now that I have had my exhaust manifold repaired, it is a lot more noticable and annoying. The clicking loudness and timing is variable, both of which increase as rpm increases. I was thinking a tapping lifter or a rocker needing tightening...any opinions?
Old Apr 21, 2005 | 11:19 AM
KED85's Avatar
Don't laugh at this but also be prepared to run it until it dies. Car/engine is 20 years old and these little engines do not last forever.
IF your oil pressure is ok & your temps stay "normal" leave it be.
UNLESS you have a cracked exhaust manifold. Then replace that. But usually just drive it until it dies.
Old Apr 21, 2005 | 11:54 AM
wpaskar's Avatar
I totally agree with that I guess...it isn't bothering me that much and I don't plan to be running the car that much longer...8 months at most
Old Apr 21, 2005 | 06:38 PM
tekk's Avatar
Car: 92 ' Camaro RS
Engine: 3.1 V6
Transmission: 5 spd
Well mine had that when I bought it, but it was low on oil. Change it and no more ticking since.
Old Apr 24, 2005 | 11:20 AM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
I had the same problem with my '90 F-150 and had it with my '90 Firebird. Some guy told me it was my lifters and try Engine Restore. It cost about 10 bucks at any Wally World and I use it with every oil change. Worked for me.
http://www.midwayautosupply.com/deta...ription.asp?65
Old Apr 30, 2005 | 11:10 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
hey jamessr, did u put in thicker oil? ive got the same problem. someone told me to try thicker oil. i use 5 30..it doesnt burn or leak...so..in ur opinion (or anyones!) should i try that? thicker and engine restore?
Old Apr 30, 2005 | 11:41 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
I wouldn't say thicker oil, try the engine restore if that doesn't work you can also try this stuff.
Lucas Oil
Old May 1, 2005 | 08:56 PM
Car: 1985 iroc-z
so i should keep the 5 30? i mean it does have 133k on it. would 10 help with friction? i was thinkin about that stuff...i'll give it all a try, thank u
Old May 3, 2005 | 08:54 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
I'm not a mechanic but I think the 1st number represents the flow rate at normal/colder tempatures and the 2nd number represents flow rate at operating tempatures. So if thats correct (please someone correct me) going to 10 30 won't make a difference. Myself I just switched over to synthetic.
Old May 3, 2005 | 08:55 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
BTW Where is New Jersey are ya? I lived in Cape May for 3 yrs.
Lbibb
May 5, 2016 12:00 AM
wanext
Oct 6, 2015 12:18 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
