what mods to do next?
Old May 2, 2005 | 07:26 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
so heres my dilema.....
you can see what i have done to my 3.4 listed below. i can get heads and intake P&P for $350 from someone who does it for a sidejob living, very well respected around me. id also get a bigger cam. now should i do that or should i get a posi (im thinking eaton or similar) full ignition upgrade, a few other suspension goodies and a couple other things that i cant think of right now.
i know to get the full effect of the engine mods ill have to have it rechipped, will i need bigger than 17lb injectors?
what i was originally getting at is, what do you all think i should do? i cant decide what route to go. either way i go, itll be getting done within the next month or two.
Old May 3, 2005 | 03:37 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
heads
Old May 3, 2005 | 06:06 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Heads AND Cam!
'88, so I see you are MAF based... good, actually! I would go with either -
(For replace and not worry about it)
Crane PowerMax H-272-2
272/284 SAE duration, 216/228 @ .050", .454/.480" lift on a 112 LSA I think this is the cam AM91 is running 14s with, in addition to his intake!
Otherwise, if you don't mind checking your valve lash once in a while, and would like to really fly - get a solid lifter cam! I'd really think the 3.4 you have would LOVE a Crane PowerMax F-228/3067-2-12!
290/300 SAE duration, 228/238 @ .050" .460/.480" lift, and a 112 LSA as well.
That solid cam + your exhaust + the McKinney intake/TB + 3.4L/T5 = 1 QUICK V6!
Old May 3, 2005 | 07:15 AM
drdave88's Avatar
Engine: 6.0L
i had thought about going w/ the cam youre running doward, or i believe it was the baja beast. i havent sat down and really looked over the specs yet though. im open to any and all advise on what cam to run.
Old May 3, 2005 | 07:24 AM
Doward's Avatar
It all depends. I actually believe a variation of the CompuCam 2030 is used in the stock 3.4L - which means you already have a 204/214, .422/.444" lift cam in there
I'd go to the 216/228, if you want a mild cam in your 3.4, and go with the solid (228/238) if you want some serious power, with a little lope to go with it
Old May 3, 2005 | 11:01 AM
KED85's Avatar
Suspension.
Ya can then really enjoy the gained HP later on, safer.
AND suspension can be done in stages so as not to deprive ya from currently enjoying the car "everyday".
DO front first, hardest, biggest effort put out.
Then subframe, then rear.
IF ya had a dying 2.8 ya wanna install more power. Ya got the more power already, enjoy it more often!
Don't forget a complete brake system overhaul, too. Hoses, bearings, fresh Valvoline DOT synthetic 4 fluid does wonders after the whole brake system is refreshed & rebuilt. Don't forget new rear wheel cylinders & fresh drum spring kit, too.
Suspension.
Then ya can really go faster, with what ya already have.
Old May 3, 2005 | 11:48 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
what is the main use of the car, and what do you prefure to have it do?
Daily driver, I'd spend some cheese on making sure the suspension is fit. (bushings, shocks, alighnment, etc).
Often drag use, the posi
Twistys, lowering springs, things to go with them, and subframes.
Expecting max power, heads n cam.
Old May 3, 2005 | 12:11 PM
KED85's Avatar
Oh forgot
Cheap posi is a SUPER sticky low profile drag racing tire on a 14" rim. That'll increase your rear axle ratio & improve your launch all at same time.
Old May 3, 2005 | 12:18 PM
drdave88's Avatar
Engine: 6.0L
i use the car for a mix of all of that. ive got a lot of the suspension done already. im waiting to do the brakes till theyre worn out. theres 70% left on the frt brakes w/ new rotors, bearings, etc. i dont really wanna toss em just yet. rears were all rebuilt just before i bought it about 2 yrs ago. im thinking ill do the posi, full ignition upgrade, gonna get some thicker sway bars, and some other lil things here and there. ill save the engine work for this winter when its stored, that way i dont have to worry about rushing to get it back out.
Old May 3, 2005 | 12:47 PM
KED85's Avatar
While ya wrecking yard shopping for the sway bars see if ya can score a Posi axle!
Sounds like ya ready for the subframe set up right about now.
I'm at that stage, sub frame connectors if possible, next.
Old May 3, 2005 | 01:19 PM
drdave88's Avatar
Engine: 6.0L
ive had Spohn SFCs in for 2 years now, i love em. theres only one yard anywhere near me that has any camaros. not looking too promising but its a shot. ill see if i can find a 4th gen w/ a posi, i guess all i need to do is get 28 spline axles with a ZT posi
Old May 4, 2005 | 12:25 PM
drdave88's Avatar
Engine: 6.0L
would i have to get bigger injectors once i have a bigger cam, P&P and all that, or will the 17lb injectors still be enough? and im quite sure after that, ill need it tuned and rechipped. anyone got any ideas to help me out here?
Old May 4, 2005 | 01:24 PM
LT1guy's Avatar
Car: 1987 Trans Am
The 17lb injectors should be fine, or you could upgrade to 19lb injectors if you do lots of head work. Tuning will be necessary, esp with the larger injectors. Funstick can help with the tuning, hes in Michigan.
Old May 9, 2005 | 08:32 PM
drdave88's Avatar
Engine: 6.0L
well, due to a recent engagement, im going to just do a cam swap this summer and probably posi and ignition. i cant afford to do the heads and intake yet($800+) im gonna try to get 1/4 mile times before and after the cam though. im leaning toward the crane cam that AM91 is running.
Old May 9, 2005 | 09:30 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Not sure what his specs are, but I'd PM him first...he has a lot more compression (and revs higher) than you, and what works for his engine may not for yours.
(LT1Guy)
Old May 10, 2005 | 07:04 AM
drdave88's Avatar
Engine: 6.0L
GOOD IDLE, DAILY USAGE AND OFF ROAD, TOWING, PERFORMANCE AND FUEL EFFICIENCY, INCREASED COMPRESSION RATIO AND GEARING ADVISED, 2600-3000 CRUISE RPM, 8.75 TO 10.5 COMPRESSION RATIO ADVISED. BASIC RPM 2000-5000
thats what ive found on it.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
