Throttle Body Bypass
Old May 6, 2005 | 12:15 PM
Dubkor's Avatar
Car: 1986 Firebird
Engine: 2.8 LB8
I've read a couple threads about this, and I was just wondering what it will actually do for you? Better fuel efficiency? More power? The lower temperature is easier on the engine?
Old May 6, 2005 | 01:32 PM
LT1guy's Avatar
Car: 1987 Trans Am
It looks a little cleaner, and makes it easier to remove the plenum. Thats about it, no performance difference that I can tell.
Old May 6, 2005 | 02:14 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
on my car i noticed no tempature difference in engine running. some people claim noticeable performance gains. some even claim "dyno-proven" performance gains. i have NEVER seen any of them post any hard evidence.
when you cut right to the core of it, it is a free mod (as you can reuse one of the two hoses allready there, just bend it in half and shove it on the other flange) and it makes maintinence easer. do you live in a realy cold clymat? the actual purpose of it is to prevent ice from forming in the TB. (i live in oregon, so no problems there) if you think you will have an ice problem don't do it (i am talking norther canada alaska here)
Old May 6, 2005 | 03:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I'm not going to say, you'll get X hp from it. But, in theory, you should run a little better. Reason for this is that the air coming through the throttle body stays a little cooler; cooler air is more dense than warm air; denser air combusts more efficiently; more efficient combustion results in more power. Someone correct me if I'm wrong on anything here... I wouldn't expect to see tenths of a second off of your 1/4 mile times or anything, but it should help with efficience a little.
Old May 11, 2005 | 04:37 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
and it's free, so when your done you can feel good about accomplishing something productive on your car for the day and it didn't touch your wallet.
Old May 11, 2005 | 04:53 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
"Its not 1 place to find 100horsepower, its 100 places to find 1 horsepower"
That is the way I see it
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
