Rear Camshaft Seal
Old May 7, 2005 | 04:35 AM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Rear Camshaft Seal
I'm doing my clutch, because my stupid rear main seal flooded the clutch, so I'm changin that. While I'm in there I wanna take care of the camshaft seal as preventive maintenance. I can't find a rear camshaft seal at any parts stores and no one knows what I'm talkin about.
What I'm wondering is if when I take that off, if you can use some gasket maker or silicone or something? I'm confused lol
Old May 7, 2005 | 10:48 AM
LT1guy's Avatar
Car: 1987 Trans Am
Go to a GM parts department, no one else has it. I wouldn't use just silicone, considering how hard it will be to get to if it leaks.
Old May 7, 2005 | 12:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Cam plug seal: #10065415 at the local GM dealer
RBob.
Old May 7, 2005 | 12:40 PM
Car: 95 Z28
ahh sweet. thanks
do you know how much it is?
Old May 7, 2005 | 02:35 PM
KED85's Avatar
Few dollars like $4-ish
MANDATORY WORK TO BE DONE
Make sure it's clean up there & ya give your ride some time to let it cure & seal.
Don't matter if a 2.8/3.1/3.4 as it seems all same part.
Lousy project to do but so worth it!
Atleast ya doing other great projects same time. That's the time to replace it, when it's exposed for easy access. Cause dropping tranny is the only way to do it.
Old May 7, 2005 | 03:43 PM
Car: 95 Z28
Ya. I'm broke right now so I gotta do it piece by piece. The Tranny has been out for quite a while and is in my bedroom I got the money to do most of it, but ran short and cant get the flywheel taken care of so It's gotta wait longer :'( So it will have plenty of time to cure lol
Old May 8, 2005 | 02:18 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Car Quest carries it (Victor Gaskets) - that's where I got mine
xxx3man`
Sep 23, 2015 10:37 PM
midge54
Aug 29, 2015 09:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 17, 2015 09:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
