2.8 with problems
Old May 10, 2005 | 03:15 PM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
2.8 with problems
My 86 firebird with the 2.8 is having a problem. When it is first started, it dogs and tries to die. Sometimes after it does this, you can smell raw gas in the car. Any ideas?
Old May 10, 2005 | 03:39 PM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
That's a pretty vague description.
What grade of fuel are you using? How does it run hot? Did it just start happening ? Is the check engine light on?
Old May 10, 2005 | 11:04 PM
Car: 91 Silverado
I use 87 in it. Once it warms up, it runs just fine. This happened last fall, and it turned out that the idiot who had my car last did a ****ty job of putting the spark plug wires on. No check engine light.
Old May 10, 2005 | 11:30 PM
Car: 88 RS
Make sure the timing is set to10 deg, the throttle body is clean, the spark plugs are gapped correctly and your using the lowest octane fuel you can find. Yes you read that right.
These engines run terrible cold. The carburated units even had heater plates under them to warm up the fuel. These have to have cold start injectors just to light the damn things off.
I set my base timing to 14 deg and buy the lowest octane fuel, and I still get a little hesitation. Give the suggestions a try and see what happens.
Old May 10, 2005 | 11:39 PM
Car: 91 Silverado
I'll check everyhting tomorrow and see what happens
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
andy74
Sep 3, 2015 08:41 AM
