Is it time for a tune up?
Old May 12, 2005 | 08:06 PM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
First off, the car fires right away, cold weather or not, but when you accelerate it from 0 it starts to hesitate until it reachs some good engine temperature.....is it a clue that I need to replace sparkplugs, rotor..dist cap....? the mpg is awesome since I full the tank up last Sunday and still have more than half of tank full, when a while ago the tank was around a quarter full only on thursdays.... the last time I checked mpg, it threw 22 miles/gallon.
Old May 12, 2005 | 11:58 PM
Mr Badwrench's Avatar
Car: 88 RS
Engine: 2.8 untill the 3800 swap
Are you running plain ole regular fuel for your area?
Old May 13, 2005 | 01:21 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
YES
if you have to ask then yes, yes it is. do a full tuneup every 30k
Old May 13, 2005 | 06:36 AM
watafo's Avatar
Engine: V6 2.8L
Yup, regular only. Last time I made a tune up was on Sept. 2004
Old May 13, 2005 | 10:06 AM
confucius101's Avatar
yea another plain old reg guy here use to run super but seen as how i'm only getting 8mpg i moved down to reg to save the .04
just reading along and figured i'd make you all feel a little better about your car's/mpg
Old May 13, 2005 | 10:33 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I do cap/rotor/wires/plugs every 6 months to a year.
Old May 13, 2005 | 03:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I do my major tuneup once a year.
If you're having trouble, just check everything- can't really check a fuel filter, but you can check plug wires (with multimeter), plugs, cap/rotor corrosion, timing, etc etc. In fact, before I go thru dyno emissions, I swap in a new "stock" air filter (and put it back in the box after I pass smog), clean/regap the plugs, check the wires, clean the dist cap, check the timing, clean the TB and IAC system, check the TPS, and a few other things.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
nuggie
Aug 25, 2015 01:27 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 13, 2015 07:35 AM
