type of oilpan gasket to use
Old May 31, 2005 | 11:01 PM
eddie jr's Avatar
Found lots of info on the procedure for changing the gasket but not really what type of gasket to use. For long lasting, is a rubber one the best to use, and put it on dry?
thanks.
Old May 31, 2005 | 11:43 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
if you can get a rubber, one go for it
Old Jun 1, 2005 | 12:12 AM
BitchinRS's Avatar
Yeah I used the rubber on my 3.1 . Bee holding up great. I did not like the cork style. was to thin and flimsy.
Old Jun 1, 2005 | 04:29 PM
eddie jr's Avatar
So you put the rubber one on dry right. What about under the timing cover? I think that is only cork and RTV. Does the rubber one cover this area and if so will it seal adequate or do you have to add RTV?
Old Jun 1, 2005 | 04:45 PM
KED85's Avatar
IF doing a timing chain replacement, use what's in the fel pro package.
Use Gas-A-Chinch for the leakfree project.
Also use a balancer snout sleeve to remove any current wear on balancer nose.
I had chance at a rubber gasket from GM & it worked fine.
Yeah rubber goes on dry I believe but also use gas-a-chinch on it too.
That stuff works very well with all gaskets.
Only place I change using that gas-a-chinch stuff is when I put something into water jacket area. Then I seek out liquid teflon, use it on the threads. That's stuff is also wonderful.
Old Jun 1, 2005 | 05:32 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Do it once, do it right! Fel-Pro PN# OS34501R Perma-Torque.
You can expect to pay $30-35 for it-money well spent!
Old Jun 2, 2005 | 09:37 PM
eddie jr's Avatar
So what is this one, is it rubber??
What exactly is this stuff? Is it a liquid or paste or something that you put on the gasket?
Old Jun 2, 2005 | 10:55 PM
KED85's Avatar
VERY CLOSE
I would say a liquid paste, yellowish in color, that holds gaskets in place while assembly.
AND then it just don't leak!
It really is great stuff!
Kinda like a great "glue" that don't stick to surfaces upon desire to remove the gasket.
See if ya can score it while gasket shopping. I've only seen it in METAL container with a brush in cap.
Kinda a great "type" of rubber cement, too. But for cars....
Old Jun 3, 2005 | 06:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What year motor do you have? There's two oil pan gaskets, one for 82-86, and another for 87-92.
Old Jun 5, 2005 | 07:09 AM
eddie jr's Avatar
It's an 85.
So would Permatex avaition sealant be similar to "Gas-a-Cinch"?? Because I don't recall ever seeing Gas-a-Cinch up here in Canada before. Just wondering f the permatex would do the same job....can it even be used with rubber??
Old Jun 5, 2005 | 09:24 AM
KED85's Avatar
Use it on surfaces of mating.... OHH SOUNDS KINKY!!!
YEP I'll bet that is same type of stuff.
Yellowish rubber cement glue, brush application, metal container.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
