140 electric speedometer
Old Jun 2, 2005 | 01:33 AM
devianb's Avatar
I heard from one guy that u can swap a 140 mph speedo into a v6 85 mph one and will work right without problems, other guy said you need a yellow speedo box for it to work.
Are any of the two right?
Old Jun 2, 2005 | 03:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Depends which year, but I'd think if both speedometers were the same VSS style, it'd bolt right in. The two styles were speedo-mounted VSS, and trans-tailshaft-mounted VSS. The trans-tailshaft-mounted VSS had a yellow VSS buffer box located next to the computer. And, of course, the speedo-mounted one hung the VSS+buffer off the back of the speedo.
So if your speedo has the VSS in the back of the speedo, you can easily swap in another speedo with the VSS in the back.
If the VSS styles were different, I'm sure it still could be made to work, but I'm not sure of what wiring would be involved to convert between VSS types.
So I think both guys were right
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
