Timing
Old Jun 17, 2005 | 08:25 PM
Bapster's Avatar
Car: '88 Firebird
Engine: V-6
Timing
Hey guys, I have an '88 Firebird with a 2.8 v-6, and I was wondering what the timing is supposed to be set at? I read on here about an '89 2.8 v-6 being set at 12* above top dead centre (think I have that correct) and was just wondering if my car is supposed to be set to the same 12*...any help would be appreciated, thanks :-)
- Brian
Old Jun 17, 2005 | 09:16 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The factory setting is 10 degrees BTDC
Old Jun 18, 2005 | 04:23 AM
Bapster's Avatar
Car: '88 Firebird
Engine: V-6
Hey Oldschool, thanks for letting me know that, very appreciated :-)...also, do you or anybody else who know's the answer to this, are the numbers for the timing mark all below TDC? as I see from a zero to a 12, but not sure is those are below or advanced, so I'm guessing that on mine, it should be at the 10* on that number tag thing, am I correct? Thanks again to you and anybody else that knows the answer :-)
- Brian
Old Jun 18, 2005 | 07:38 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Yes, all the marks on the indicator are for Before Top Dead Center. Zero being top dead center and all the rest are before tdc. Make sure you disconnect the EST connector or it won't be set right. https://www.thirdgen.org/techbb2/sho...=est+connector
edit: some people do set it at 12* for a little more power, I don't see the need for a daily driver. It's easy enough if you go to the track to reset it before running and then change it back when you're done.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
