Need help iding a block
Old Jul 7, 2005 | 12:50 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Need help iding a block **EDITED now with pictures**
I've had this block for a while now and have been buying parts in preperation for a rebuild, now i have a few questions, the motor in my car has a timing chain cover that bolts to the pan, the new motor sits on top of the pan with a thick rubber gasket sealing it.
now the motor in my car is supposed to be original but i cannot verify this, do i have an earlier style cover and pan on my car, or is the new engine from a later year?
any help would be great as this has been bugging me for a long time
Old Jul 8, 2005 | 05:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
come on guys, someones got pictues to help me out
Old Jul 8, 2005 | 06:27 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
how bout you post some pics of the cover, & any numbers that are on the block
Old Jul 8, 2005 | 06:46 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
will do
Old Jul 8, 2005 | 07:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
my 1991 camaro motor, tcc sits ontop the pan, thick gasket.
my 1993 s10 motor I had, tcc sits ontop the pan, thick gasket
both 3.4s I used to replace above motors, tcc sits ontop the pan.
Any help?
Old Jul 8, 2005 | 08:18 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yeah i have a feeling the actual block might be a 3.1 block, with a 2.8 intake put on top.
i'm hoping anyways
i'm gonna have pictues and numbers up in a few minutes
Old Jul 8, 2005 | 08:24 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
heres the cover
numbers on the cover are
hucho un mexico
File Type: bmp
Old Jul 8, 2005 | 08:25 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
front of the motor i have
the front passenger side fo the block has on it
GM 2BL G
and the rear passenger side fo the block has
9J67
File Type: bmp
Old Jul 8, 2005 | 09:45 PM
Engine: 5.7 / 7.4
it might be a 3.1 . Here's a pic of the 85 2.8 front over & you cain see that the inlet/outlet channels are opposite:
unless it's different due to teh full serp belt configuration.
any spots for ka-nock sensors?
Old Jul 8, 2005 | 09:52 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
actually both the 2.8 and 3.1 have the knock sensor
but this engine didn't come with a csi
so that leads me to believe it might be 3.1
i'm happy even if its only a 2.8
Old Jul 8, 2005 | 11:25 PM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
for the record, neither my 85 2.8 or my 88 2.8 had a knock sensor, but my 91 3.1 does. my 85 2.8 had the pan bolting to the timing cover, but the 88 had the thick rubber gasket, so they evidently changed it betw/ 85 and 88... but odds are it's a 2.8 if it bolts to the pan...
Old Jul 8, 2005 | 11:40 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
yeah i know they changed over in 88, the new one lays on the pan.
i guess this is something i'll just never know
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
