factory tach and gauges
Old Aug 6, 2005 | 03:26 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
How many V6 owners have swapped out their warning lights for the factory gauge clusters on 85'-87' Firebirds?
Old Aug 6, 2005 | 10:25 PM
KED85's Avatar
I still have mine to do
IF you are seeking the guage package MAKE SURE YOU GET the 1985 set up for your car.
And ALSO MAKE SURE THAT you score a V6 set up not a V8
How to tell
EASY
Oil pressure gague on the V6 gauge is going to read to 80!
V8 reads only to 60.
What also to score is the two back block plugs with the wires attached. That way one only needs add from coil a white wire. Rest of wires only need swap around from idiot light block dash plugs to the new gauge.
Look for my old post called
Swapping the idiot gauges...I have pics & a block plug pictures.
Old Aug 6, 2005 | 11:14 PM
oldschool's Avatar
Engine: 2.8 LB8 HO
The only problem with re wiring the connector plugs for the gauge cluster printed circuit seems to be the charge indicator light that is present with the idiot light cluster. The GM service manual diagram shows the light is part of the charging circuit for the alternator. Omit the light, and the alternator won't start charging. It also seems that it might be possible to use either the choke, or up shift light spots, on the V6 gauge cluster to still have a "charge light" there, and keep the alternator working.
Old Aug 7, 2005 | 07:52 AM
KED85's Avatar
When I looked at the Helms book for guidance, and then color matched all wires/connections, every one "fit", except the missing one, the one white wire from coil area to the gauge cluster.
I don't doubt ya, but this is what I found when I researched.
Old Aug 7, 2005 | 04:19 PM
oldschool's Avatar
Engine: 2.8 LB8 HO
Yeah, the factory manual show the charging circuit is different for the warning light and gauge cluster cars. Maybe not that big a deal though.
Old Aug 7, 2005 | 10:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
dammit Karl, I'm gonna have my bird on the road before you swap in that cluster.
Old Aug 7, 2005 | 10:32 PM
KED85's Avatar
Rebuilding a project for sale takes priority anyday!
Stinks, don't it?
Old Aug 8, 2005 | 07:01 PM
oldschool's Avatar
Engine: 2.8 LB8 HO
I don't think this swap is too tough, but there are a couple of issues that have to be worked out and the charging light on the idiot light cluster providing resistance in the charging circuit to "switch on" the alternator is one of them. The warning light circuit has to be maintained, or else a different alternator has to be installed.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
