Rear main
Old Aug 6, 2005 | 10:56 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Rear main
Can anyone give me a good step by step on changing out the rear main seal? Its a 1988, so its gonna be 1 piece design
Old Aug 7, 2005 | 11:34 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Pull driveshaft
pull trans
pull clutch or TC
pull flywheel/flexplate
rip out old seal w/seal puller
tap new seal in
everything else in reverse order.
Old Aug 7, 2005 | 12:03 PM
KED85's Avatar
While you are "there"...
Say hello to the rear cam shaft seal, too.
Replace that now. It's right above the rear main seal.....
Never hurts to use some gas-a-chinch on the seals......
PS Buy the best gaskets/seals you feel you can. GM gasket product ain't bad stuff right now...
Classify this as a pure joy a minute mission.
I'd make sure do not need tranny rebuild same time, only to discover later on, you "did" and need remove all this again.....
Old Aug 8, 2005 | 02:52 PM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
I'm just selling the car, but i gotta have it running before i can get decent money for it.
Old Aug 8, 2005 | 08:05 PM
KED85's Avatar
The other gasket is like also $3 - $5 range & seriously you'll find it also leaking & IF ya wanna sell the car it being leak free is a good thing.
Get them both I mean the opportunity for easy replacement will be in your hands
Shame you have to sell ride after sealing those things up.
Those two items are number one on leaks for these engines.
xxx3man`
Sep 23, 2015 10:37 PM
Warlocksirix
Sep 3, 2015 12:26 PM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
