Performance Ignition parts for 3.1?
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Would it be worth the money to upgrade to better ignition parts? such as the Accel Cap/Rotor, Wires, Coil and plugs?
Or would I see the same results with generic plugs/wires/dist caps and rotors?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
cardone distrib
Blue steak cap/rotor
Accel 8mm wires
MSD coil
delco ICM (isnt that it, its to early in the am)
Currently r43tsk plugs, soon to be halos.
Accel 8mm wires
MSD coil
Engine: 350 S-TPI
My old boss, old co-worker, and another friend started the company.
Appears they sold it to someone else, but are still making the plugs. Ones for our cars should be ready in about a month so the email said.
Car: 91 Firebird
Engine: 3.1 V6
Originally posted by 91greenbird
I have accel cap & rotor, accel super coil, accel 8.8mm wires, and accel spark plugs.
Originally posted by V8 Slayer
Did you notice an increase in performance with the performance ignition parts? Wether it be horsepower or torque or mileage...
the best thing to go with is a good set of spark plug wires, a set of STOCK OEM AC DELCO steel tipped plugs (none of that platinum crap), and an Accel or MSD aftermarket coil. I personally prefer the Accel ignition coil. At the time I purchased mine, it produced the highest voltage out of all of them, I think it's still like 5,000 volts higher than the MSD.
In addition to going with these parts, I'd also recommend that you inspect, replace, or add ground straps, it'll help a fair amount.
Anyway, although you can build a little bit more horsepower by going with a SLIGHTLY larger gap (not much) when you use a high output coil... most of the power that you FEEL is actually power that was always there. Kind of hard to explain, but basically your motor sort of "runs out of breath" above 4,500 rpms.
It runs out of breath for a couple of reasons, the first is that the intake plenum is very restrictive at the neck, the second is because at the higher rpms, the capacitor that is the coil simply cannot produce a large enough jolt of electricity fast enough. Basically, the coil becomes inneffective over 4,500 rpms at producing the necessary voltage for optimal operation.
When you replace your STOCK ignition coil with an Accel or MSD aftermarket coil (about $10 more than an OEM replacement), you'll notice that above 4,500 rpms your motor will CONTINUE to build power... as apposed to the normal feeling of it starting to drop off.
It also improves your emissions, slightly better throttle response, and allows you to advance your timing a little bit as well.
It's a very inexpensive upgrade that gives a pretty decent amount of improvement. FYI, keep your stock one in the little compartment in the back.
One more thing... if you have a lot of cash to burn, you can get an MSD 6AL ignition box... I think they're like $250-300.
Originally posted by DustyJL
Just curious how much does everyone advance their timing? I just installed a MSD coil with Accel 8.8mm wires.
I advance my timing as high as I can go up till (but not including) the point at which my engine starts to ping. I also use high octane fuel so that I can advance the timing slightly more.
With the price of gas, I'm going to have to start going with regular 87 octane and detuning it slightly. I don't think I really gain that much more horsepower by going with the 93 and advancing the timing even more.
Car: 87 camaro(Temporary insanitee)
Engine: 2.8
Transmission: Non worldclass t-5
anyone got a p/n and price on the mallory dist.... i have been trying to get into the online catalog for a week now, and it won't let me do anything. just freezes the computer every time....
If you know something I don't, PLEASE let me know... I would LOVE to have a Mallory distributor on my Fiero.
Engine: 2.8
i just want a better dist for the camaro, esp since i am gonna be running a blue bottle soon, and little "fan" to feed air to her....
fyi, no more than 75 shot, right now, just gonna go with a 50 shot. 10% overdrive is what i am looking into for the blower or about 10 psi
Engine: 350 S-TPI
my cardone is not a performance distrib. However, if you compare the two designs, mine is much better thought out.
I have posted pictures here before of it, but it was about 2 years (or more) ago.
Engine: 350 S-TPI
noobs
see below, profile, pm, email, www, seach, buddy
:delete link:
:delete link:
Engine: 2.8
i just found a distributor from mallory..... at advance autoparts.
mallory unilite 4569201 here i will put the link on here for anyone else. says for the 2.8 and not the o.e replacement, but i am guessing that it will fit without doing too much modification!!!!
http://www.partsamerica.com/ProductD...pe=218&ptset=A
Engine: 2.8
i dunno but i will be looking into it soon.
i will let you all know what i find out......
personally i would rather have a mallory ignition on this thing than a stock or a oe replacement....
Engine: 2.8
money is not a factor in my decission, computer advance sounds better for me, since i need the computer anyway. i would go with the vacume advance, but i really don't like fooling around with the springs and counterweights again on another car, and i want to keep the computer advance there.
