Swirch from FI to Carb
Old Aug 26, 2005 | 06:39 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Just wanted to know if anyone has done this transformation and if so how difficult was it. Not really worried about the gas mileage since this is my toy but rather it will be easier for me to hype up since I am use to cab engines. Will this have a major affect on the computer or what?
Old Aug 26, 2005 | 11:43 PM
DFJ6000's Avatar
Car: 88 Camaro
Engine: 2.8
actually id like to kno the same thing dude, im sooo a carb guy...it would seem it would give ya more power but thats just me. and i kno edelbrock makes a performer for the 2.8's
Old Aug 27, 2005 | 12:09 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
you could go old school and completely discard the computer. ive never really looked into it, but i gotta imagine you can get a fan or wire up one so you can run w/ no computer. the v8 guys do it all the time, not to brag them up, lol.
Old Aug 28, 2005 | 02:12 AM
LT1guy's Avatar
Car: 1987 Trans Am
It could be done pretty easily, but why? Its not going to make enough power to be worth it, the mileage will suffer, and driveability would be out the window. You could easily fix anything wrong with the FI system and computer controlled ignition for the cost of an intake, carb, and distributor, and have a much better car for the effort.
Old Aug 28, 2005 | 06:36 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
not so. cause you can tune your fuel and timing so much easier on a carb.
like go with the performer 4 bbl drop a 2 inch spacer and add a scoop. go with a mallory dist, coil, box and accel plugs and wires.
Old Aug 28, 2005 | 11:16 AM
KED85's Avatar
As said the effort is wasted.
UNLESS YA GET the change over parts for free, why bother?
You can fix your EFI set up so much easier.
Add the costs up first before ya pick up a wrench.
Or just go buy a 1983-1985 Blazer and have at it, as it's already carb'd
Old Aug 28, 2005 | 06:24 PM
Car: 91 RS
Engine: 5.0 tbi
yeah it can be a pain.........like um......STILL NOTHING ON THE F**KING STUDS I NEED ERRRRRRRRRR
Old Aug 28, 2005 | 07:09 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
unfortunately I'm doing this swap w/ a vee-ate . Check out the v6~v8 sticky in the engine swap forum. Lots of good info regarding the fulie to carb issues.
Old Aug 28, 2005 | 08:56 PM
KED85's Avatar
Hillco could not help on the carb studs?
Old Aug 29, 2005 | 12:30 PM
Car: 91 RS
Engine: 5.0 tbi
yeah but that'll take a while.......duh should ask about over nite.....but i do have an idea
Old Aug 31, 2005 | 06:22 PM
Car: 91 RS
Engine: 5.0 tbi
WELL. got it together BUT 1 prob still........1/4 inch shy and the linkage still hits..................Any idea how much room we have in relation to the valve cover so Ican maybe reses the cover at the linkage?
Old Aug 31, 2005 | 07:30 PM
KED85's Avatar
You are blazing new territory.
Let us know how well ya do!
Old Sep 1, 2005 | 06:08 AM
Car: 91 RS
Engine: 5.0 tbi
yeah I am getting brave........goin to work where my car is on my day off instead of spending time with my wife..........well then again that might be aplus
Old Sep 1, 2005 | 10:54 AM
wildponies3's Avatar
Car: 87 camaro(Temporary insanitee)
Engine: 2.8
Transmission: Non worldclass t-5
depends on how you look at it..... sex life going down the drain........ or ........fighting all the time.......
Old Sep 1, 2005 | 11:36 AM
Car: 91 RS
Engine: 5.0 tbi
Found the bolts....the size is 8MM 1.25 X 60MM. Only problem with them is you have to pull the bottom half of the Carb to get the bolts in. On the other hand if you were to use a 1 inch spacer you could use a little shorter bolt that should just slide right in.
I had to use a 1 1/2 inch spacer to clear the linkage and to do that I had to stack a gasket or two.
I will let y'all know how it goes when I get the extra gasket tomorrow.
Old Sep 1, 2005 | 03:27 PM
KED85's Avatar
I'm learning while ya typing & trying
Hope it's worthwhile.
I can't see why not due to this is "what edelbrock did" for "their" version of the factory 60* V6 intake.
Old Sep 1, 2005 | 05:55 PM
Car: 91 RS
Engine: 5.0 tbi
AS of right now I have 6 gaskets stacked with a copper sealer between.......If it works I will see about getting one cut......OR coating the gaskets with raisin.......no that'sfood........uh resin......
I hate spelling crap
Old Sep 1, 2005 | 10:57 PM
Engine: 2.8
dude, do you need a aluminum spacer, you pay shipping, and i make you one out of aircraft aluminum next duty day. just send me a gasket and that is what i will make it to! save you the whole "well maybe it will work, maybe it won't" from the start!
(besides i like doing one off things like that!!!!
Old Sep 2, 2005 | 09:41 AM
KED85's Avatar
Keep at it
I'm aching for results of "gains" or something.
Old Sep 2, 2005 | 08:40 PM
Car: 91 RS
Engine: 5.0 tbi
Rain Delay
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
