Junk Yard Finds Rock
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
85-90 door section GFX, 7 a side
85-90 rocker panels, damaged due to idiot with fork lift
(I need some if anyone knows of any)aftermarket fiberglass hood, 30 bux
Orb, 2 bux
aluminum vent pipe, 1 bux each (got 2)
egr mount, 5 bux
overall after taxes and "fees" I spent like 62 bux?
Anyone need an LB8 intake, they had another
plenty of v6 fbody engines 2.8/3.1, no 3.4
plenty of firebird hoods
full 5sp setup for a v6
very few camaro body panels, plenty of bird body panels
Anyone know if the firebird hatch is same as camaro? they got a hole-less one, and I need it.
Engine: 350 S-TPI
they got all of it. Black belts, spoilers. About 3 bird hoods., drivers door I think 1 or 2.
Yard is "You pull it", along hwy 67/167
Jacksonville, AR
or it may be listed as
Cabot, AR.
Jacksonville, AR
Cabot, AR.
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
found a 'maro today with almost perfect black leather interior, but i dont have the time to bother pulling and cleaning it all(i cant use it). but i did find a t/a with an a/c delete heater box . . . . yum. didnt have time to pull the whole box, but itll be there tomorrow.
as well as the stuff i came for, a 5-speed console, a u-bolt, a headlight switch, a shifter, and some shift boots. all for $30
Engine: 350 S-TPI
damn you, I've been looking for a delete box.
You also reminded me of another little part I need. Gotta remember that next time I go.
Anyone tell me if the ta and maro hatch are the same? Any year differences?
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
IF you cain find some power door lock solinoids & the metal rods for them, I'll reemburse you + a finders fee. nothing out here
Engine: 350 S-TPI
project, are you saying basically to add power door locks?
I will see if they are open monday, but other then that I dont know when I will beable to get back.
kretos, thanks
kretos, thanks
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
ask me how i know
I bought a set of solenoids w/rods and a harness w/ switches off eBay. Then found out I needed the bellcranks too which weren't included.
Engine: 5.7 / 7.4
thanks, but I ws able to score everythign but the solinoids & rods. I'm even switching to power windows too.
good link on that: http://www.p71interceptor.com/thirdgen/powerwindows/
Car: 1987 Trans Am
Originally posted by Gumby
I think only the TA is different.
Car: 1987 Trans Am
I had two good "cheap" junkyard scores recently...
a nice hardtop overhead console (needed lens, flashlight, and front light), a Wonderbar, and a nice 5 speed Firebird shift plate (needs a new boot, but the plastic was really nice), all for about $11
An overhead console lens, the complete front light assembly, and a Camaro flashlight...all for $4 ! (Was going to be $5, but I had 4 ones and a hundred, and he didn't want to make change!)
If anyone wants to trade their Firebird flashlight for my Camaro one, please let me know!
