Trans Cooler Lines
Old Sep 7, 2005 | 10:50 PM
Persanity's Avatar
Car: 1987 Camaro
Engine: 2.8 soon to be 3.1 Twin turbo
Axle/Gears: No idea ATM
Trans Cooler Lines
Ok so on the radiator there is a upper and lower fitting for the transcooler lines and on the trans there are (obviously) 2 of the same type of connecter, but on the trans there kinda staggered not really a upper and a lower.... so my question to anybody that can help is this, does it matter how the lines are hooked up? or do they need to be done a certain way? my haynes manual just says remove/install transcooler lines not how to do it, thank you in advance guys.
Old Sep 7, 2005 | 11:08 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Re: Trans Cooler Lines
not really...
you would rather have the lower fitting (if there is one on the rad) to the output of the trans.
Just for easier flow...
in high, out low...
Old Sep 7, 2005 | 11:20 PM
Persanity's Avatar
Car: 1987 Camaro
Awesome, i guess i was correct in thinking its just a pump then,and if the upper trans line is connected to the lower radiator fitting, itd just need to pump more fluid to build up pressure, but itd still work all the same, great, no lowering the trans again *phew*
Old Sep 7, 2005 | 11:25 PM
Persanity's Avatar
Car: 1987 Camaro
Old Sep 7, 2005 | 11:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're using the factory lines it's nearly impossible to connect them wrong without bending them all to hell. The bottom port on the transmission should send fluid to the bottom port on the cooler.
Old Sep 8, 2005 | 03:58 PM
Persanity's Avatar
Car: 1987 Camaro
the engine i bought came with cooler lines, it has about 5 inchs of metal line from the tranny, some length of rubber hose and then about another 2 inchs of metal line into the radiator, they are exactly the same length, i guess ill switch around the fittings on the tranny, good thing i lost my drive shaft ujoint retainer clip bolts and dont have my driveshaft in.....
84z96L31vortec
Aug 20, 2017 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
