intake manifold
Old Sep 12, 2005 | 11:19 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
intake manifold
ok im leaking from the back of the intake manifold guess im gonna half to replace the gasket,. was hoping some of you all could tell me thru the process., like about how long should it take to replace?? also since ill be in there and taking things off,. is there any thing i should watch out for.,or maby i should clean real good???all info is helpfull thanks, in advance? ? ? ? ? ? ?
91r/s 3.1 auto
Old Sep 13, 2005 | 01:09 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
back of teh intake manifold, or the distributor. look real close.
Old Sep 13, 2005 | 01:17 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
first off leaking what?
vacuum?
oil?
fuel?
Vacuum, get an intake gasket set.
Pull upper, 2 fuel rail boots, and lift side to side, not front to back. It pops right out if you go side to side.
remove 4? bolts holding middle intake.
stuff CLEAN rags in intake ports to the head.
Scrape as needed.
put on new gasket, and reverse.
Oil, your gonna have to do all above to get distributor out anyway, so add a distributor o ring to the gasket set.
pull cap, mark rotor.
remove hold down bolt.
lift GENTLY, AND PAY ATTENTION TO ROTOR ROTATION. Mark where it is on full rotation removal. This will serve as your startihg point on reinstalling it.
put in new o ring, reverse.
Fuel, do first steps, add fuel injector o rings and isolators, follow rest.
Old Sep 13, 2005 | 02:52 AM
gottfuel's Avatar
WELL YES IT IS THE REAR INTAKE ITS LEAKING OIL!! SO DO I REALY NEED to pull the ditributor.,., im concernd about what you said about markin the rotor and then it spining to come out.,,. i guess im worried ill mess that part up.,
Old Sep 13, 2005 | 06:52 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
yes you do need to pull it, it hangs over part of the back of the intake to lift it up off one of the studs. just mark where the number 1 cyl lines up on the intake, pull it. it may take some trying, but when its all the way back in, make sure it lines back up to that mark.
Old Sep 14, 2005 | 03:25 PM
V6sucker's Avatar
Engine: blown up
no need to yell...
I asked what it was leaking as you neglected to mention that detail.
Otherwise, follow above and you will be just fine.
It is hard to mess up if the lines line up...
if they do not, remove and try again.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
