Port/Polishing heads?
Old Oct 2, 2005 | 08:29 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Good friend of mine has access to a machine shop and likes to work on engines. Wiuld it be worth porting and polishing the 3.1 heads? I would think he knows what hes doing since he worked on hundreds of engine before. Any other modifications be required with porting/polishing of heads?
Old Oct 2, 2005 | 08:51 PM
1slow8t3's Avatar
Car: 83 v6 firebird
Engine: None right now
Transmission: none right now
Axle/Gears: 3.08 one tire fire
yes it would be! just as long as they know what they are doing!
Old Oct 2, 2005 | 09:07 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
yes you need to find someone that actually deals SPECIFICALLY with these heads, as most people just screw them up by doing things they should not do and harm the performance of them.
Old Oct 2, 2005 | 09:08 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Hes worked on MANY MANY engines, mostly SBC's and big blocks. He's had some experience with V6's so I can assume he might know how to do it right. It was his idea to do this to my car anyway.
Old Oct 2, 2005 | 09:18 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
what all can be screwed up from people P&Ping these heads aside from grinding out the "hump"? im curious because im looking into this this winter and want to know what to make sure doesnt happen.
Old Oct 2, 2005 | 09:38 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
How long does it take?
Anything else need to be modified? ECU? Intake/Exhaust Manifolds?
Old Oct 2, 2005 | 10:10 PM
V6sucker's Avatar
Engine: blown up
that is the main thing NOT to do. But alot of "V8" porters, do it... and then it kills the flow rates of the head.
Old Oct 2, 2005 | 10:11 PM
V6sucker's Avatar
Engine: blown up
how long? hell I would expect a few days at the least. A GOOD one up to two weeks. But that would contain flow bench testing to ensure equality between ports.
Do you need to modify anything? not really. Just reset the ECM.
Old Oct 2, 2005 | 10:14 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Reseting the ECM meaning un hook the battery for 20 minutes?
I think I just might go ahead with this. Do they do intake and exhaust sides or only intake?
Old Oct 2, 2005 | 10:18 PM
V6sucker's Avatar
Engine: blown up
10-15 should do it.
Yes, both sides should be done, but in different manners and final grits.
Put it this way, the last head I did... I took 2 weeks to finish and the exhaust was down to 400 grit... yes, there was an actual reflection in the aluminum ports. The intake I took to 220 grit. Still some turbulance to mix the A/F up, but still allow smooth flow.
Old Oct 3, 2005 | 04:03 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
once compleated would there be any change in proformance?
And is there any noticability in sound??
Old Oct 3, 2005 | 09:16 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Around the end of October i'm being forced to take a vacation from my work. I think i'll have it done then since I would be able to use my mothers car to get to school.
Old Oct 3, 2005 | 09:33 AM
V6sucker's Avatar
Engine: blown up
sound? not really.
Performance? might be noticable, if done correctly.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
