will these springs work? rear / rant
Car: IROC Z
Engine: 5.7
the whole point of this thread is the springs im looknig at TAG SAYS NNL 10018091 these work on my v6? and how hard to replace them?
**because**
after replacing front springs the rear looks squatting now. was hoping the front would settle but i dont think its going to.
well my car is pissing me off. theres nothing really wrong with it. its just i been looking at some really nice ones on here, and then i see pics of my car when i first got it. so i go look at it in the drive and its ghetto now.
ive been through a love hate replacing hell with this car. i hate seeing it die so i try to keep it up by replacing everything. a photo history can be seen here
http://kcampbell2.photosite.com/
this is a pic when new.
70,000kms vs saggy bum 144,000kms
it sort of makes me want to replace everything thats wrong with it. really, this morning i couldnt get back to sleep so i was looking at nice sunset orange camaros.... i need to /end ghetto
starting with saggy bum
**because**
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Myself, I would run a good set of coil over shock and just leave to stock spring in place.
They just work better for osme reason. I think it due to the wider spacing. The spring and the shock work together better near the ends.
Car: IROC Z
Engine: 5.7
i replaced the rear shocks in june. no point in replacing those with somthing else when the springs are the problem.
will NNL 10018091 fit my car or are they v8 only and will jack my *** end up?
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
did that rear window black out come with the car or did you pick it up seperately? i've been looking for one of those for the longest time. I love em, and i can't find one for the life of me
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Old pic but you can see I have an even ride hight F/R
http://viragotech.com/car3.jpg
And things look rust but are still good.
I should have but didn't preload the right side spring a tad more.
But I don't race on purpose most times.
http://viragotech.com/coil1.jpg
Ride and look is nice. I like the even sized tires and spacing look.
stock coil don't work cept maybe on super hard bumps.
Car: IROC Z
Engine: 5.7
see but you didnt replace the front springs and not the rear. i just want to know if the springs NNL 10018091 are a direct replacment for my car.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Front springs were fine. Springs usually don't wear out if your shock or struts are good. Why my backs were saggy. To many miles with blown shocks, making the springs do all the work.
If your springs were bad in the front, id suspect somone drove on bad struts for a while. Springs can't go bad of the struts or shock are good.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
what brand of springs are they. why don't you just get stock gm replacements if you want stock ride height
<-- this is me trying to ANSWER your question, not sell you somthing.................. just giving you crap gumby
that looks like a cool setup by the way. you make those?
that looks like a cool setup by the way. you make those? Last edited by Xophertony; Oct 12, 2005 at 02:53 AM.
sailtexas186548
Aug 26, 2015 03:32 PM
AkDrifted
Aug 17, 2015 07:45 PM
