car dies
Old Oct 12, 2005 | 08:03 PM
jerryman762005's Avatar
Car: 89 camero rs
Engine: v6
Transmission: automatic
car dies
i have a 89 rs, when I get the car to opperating temp and drive it at stops it dies without the air on. Any suggestions
Old Oct 12, 2005 | 09:16 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Without the air on? clarify? the air conditioner?
Old Oct 12, 2005 | 09:19 PM
Car: 89 camero rs
Engine: v6
air conditioner
Old Oct 12, 2005 | 09:24 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Replace your ignition module. Better yet, rebuild your distributor.
Old Oct 13, 2005 | 03:39 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
clean you idle air control valve (IAC)
do a search on how or check haynes
Old Oct 13, 2005 | 06:09 AM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
....and then check your injectors for one that is close to no resistance....
Old Oct 13, 2005 | 07:18 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Not even sure what you mean.
If the car only dies when you stop.
Its a vacuum leak 99% of the time.
The ac being on or not shouldn't matter.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
