v6 perf
Old Oct 13, 2005 | 05:26 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
v6 perf
is anything availible to boost a 2.8 to 175 hp if not is there anything at all that will make it perform ?
Old Oct 13, 2005 | 06:48 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
a 3.4 + headers/intake
Old Oct 14, 2005 | 04:29 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Old Oct 14, 2005 | 06:00 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: v6 perf
all the above, and depends if you need it to pass **** e-check
Old Oct 14, 2005 | 07:39 PM
deadman's Avatar
Car: 89 camaro
im not coming up with anything in the search and i dont know what a **** e check is.
Old Oct 14, 2005 | 08:47 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Smog check
Emissions check
etc....
It will take more than one thing to get it up there, at least without a turbo or nitrous.
edit: here's a post with some good info (searched for horsepower): https://www.thirdgen.org/techbb2/sho...hreadid=314858
Old Oct 14, 2005 | 09:05 PM
drdave88's Avatar
Engine: 6.0L
just search in the v6 forum for "mods", youll find all you need.
Old Oct 15, 2005 | 04:08 PM
deadman's Avatar
Car: 89 camaro
1 - Tune-Up
2 - Synthetic Motor Oil
3 - K&N Air Filter
4 - Accel Super Coil
5 - Replace your factory catalytic converter with a hi-flow one before you replace any of the rest of your exhaust. It makes almost as much of a difference as headers do.
6 - Performance Muffler
7 - Underdrive Pulleys
8 - Headers (do they make them for the 3rd gen V6?)
9 - Port-Matching of all the intake pieces (will net you about 10 horsepower, seriously... anyone disagree?? shoot me an e-mail)
10 - 1.52:1 or 1.6:1 roller rockers
11 - Better rear gears
12 - lighter flywheel
13 - larger throttle body
14 - high performance cam from Crane or Comp Cams.
15 - At this point, you may want to consider 17lb Accel Injectors and an adjustable Fuel Pressure Regulator.
You'll be putting out about ~185 horsepower at this point, but about ~200 ft-lbs of torque. In your third gen, that'll be good for low 15s.
If you want to keep your motor, you can swap in 3.1 parts (crank and pistons), or you can opt for a 3.4 from the 93-95 Camaro / Firebird. (Direct swap... no fuss...)
is all this true and about how much would it cost for all this?
Old Oct 15, 2005 | 09:50 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
That's a lot of work to do just to get into the 15s IMO. If you're going to do that much work to a motor, might aswell get a better motor to start off with. Only mods I have done is a K&N filter and exhaust... I wish I didn't even have an exhaust or the stance of my car because most people think it's a hotrod, and it's far from that lol. Its how it came when I bought it.
"hey how fast is your car?"
me - "it's not fast at all"
"its a hot rod, its gotta be fast"
me - "its just a v6"
"oh"
Makes me depressed and want to get a V8 lol hell, I already have the gas mileage of one... 10mpg
Old Oct 15, 2005 | 10:33 PM
Persanity's Avatar
Car: 1987 Camaro
Engine: 2.8 soon to be 3.1 Twin turbo
Axle/Gears: No idea ATM
my 90 rs with a 3.1 v6 gets 20-22mpg, u sure urs only gets 10?
Old Oct 16, 2005 | 11:02 AM
Doom Sayer's Avatar
Yeah, and I'm not the only one who gets crappy gas mileage with the 3.1.
Old Oct 16, 2005 | 01:30 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
i get EXTREMELY crappy gas mileage right now, cuz i have a hole in my gas tank
but i just jbwelded it so were all good now
Old Oct 16, 2005 | 04:20 PM
deadman's Avatar
Car: 89 camaro
would a computer chip help? will s10 blazer headers fit my car? i see that more companies make they for the s10 than the camaro
Old Oct 16, 2005 | 07:02 PM
Engine: 5.7 / 7.4
blazer headers will fit your engine, not neccassarily your car. Just get teh Pace Setters that WILL fit.
Chip should be theeeeee very part you get so it cain be programmed to take advantage of all your mods.
Old Oct 16, 2005 | 07:27 PM
deadman's Avatar
Car: 89 camaro
i seen that they were almost 275 from pace setter and about 175 from other companies is pacesetter worth the extra 100 dollars? ive bought cheap headers for my other 383 camaro and they were 125 and worked just fine.
Old Oct 16, 2005 | 07:52 PM
drdave88's Avatar
Engine: 6.0L
what other companies sell headers for our cars for $175? the ones from pacesetter are about $220 through summit and comes w/ a y-pipe.
Old Oct 17, 2005 | 04:32 PM
deadman's Avatar
Car: 89 camaro
hedman are 185.00
flowtech are 160.00
hooker are 540.00
edelbrock are 289.00
these all are for the s10 blazer not just our camaro . if i run duel exhaust i think they will work i really wouldnt need a y pipe.
Old Oct 17, 2005 | 06:30 PM
drdave88's Avatar
Engine: 6.0L
the headers will bolt up to the engine, but may need modification to clear the firewall, and if they do, youll need to fab up a y-pipe. it would be easier and probably cheaper to get the pacesetter headers from summit, they bolt on in a couple of hours and have everything you need. some have reported having to lengthen the o2 sensor wire, but i believe they were all 3.1s. i didnt have to for mine. unless you make the y-pipe yourself, itll cost more to have one made than just buy the set. and also check the primaries size on the rest, some may be 1.25", the pacesetters are 1.5".
dual exhaust will be overkill unless youre doing some serious engine work to allow for it. but even then, may still be overkill. the biggest exhaust on here is 3" catback, and thats on highly modded engines. a 2.5" catback will be more than enough unless youre going to go big, ie. cam, P&P, and even forced induction. double check w/ AM91, but i dont think his exhaust is even that big.
Old Oct 17, 2005 | 07:24 PM
deadman's Avatar
Car: 89 camaro
ill probbly get the comp or crane cam and headers first . ill lose the cat converter and run a 3 inch exhaust and a good flowmaster muffler my father in law has a pipe bender so i can experiment a little. this v6 deal is more involved than just building a carbed 350 . this is my first experience with a v6 of any kind.
Old Oct 17, 2005 | 08:15 PM
drdave88's Avatar
Engine: 6.0L
i remember a thread about the 3" exhaust being perfect, but i think its for a heavily modded 2.8 or a modded 3.4. do a search on 3" exhaust from redraif. you should find all you need to know about which exhaust to go with.
Old Oct 17, 2005 | 09:32 PM
Engine: 364ci LS2
Axle/Gears: 3.46
3" exhaust on a v-6 ? ? ? ?
if your not running a turbo or s/c, slap yourself.
sounds a little too riceburner for me
Old Oct 17, 2005 | 09:41 PM
drdave88's Avatar
Engine: 6.0L
https://www.thirdgen.org/techbb2/sho...ight=3+exhaust
heres the thread
Old Oct 18, 2005 | 08:05 PM
deadman's Avatar
Car: 89 camaro
if i were to put an intake from my 2.8 88 camaro will it bolt onto a 2.8 out of an 84 blazer?
Old Oct 18, 2005 | 08:15 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
are they both MPI?
are they both GM engines?
Are they both a 2.8?...
then you have your answer...
Old Oct 19, 2005 | 04:27 PM
deadman's Avatar
Car: 89 camaro
both are chevy 2.8 the 2.8 in my camaro is mpi the 2.8 in the blazer is carb
Old Oct 19, 2005 | 05:56 PM
V6sucker's Avatar
Engine: blown up
then no. You would need to convert one vehicle to the other type, either MPI, or CARB...
this would also include changing fuel pumps, not an easy thing on a camaro...
82tabird
Dec 21, 2015 10:22 PM
DJanes97
Sep 1, 2015 02:55 PM
colinfinkle
Aftermarket Product Review
32
Oct 27, 2001 11:08 AM
FSTFBDY
Apr 7, 2001 10:52 AM
Godti
Oct 5, 2000 12:39 AM
