V-8 Swap?
Old Oct 30, 2005 | 03:31 PM
3rdgenz4me's Avatar
V-8 Swap?
I am looking at a 3.1 w/a 5-speed. The engine is seized and I am wanting to do a 350 swap. My question is will the 5-speed tranny from the v-g work with a small block or is it easier to swap in a t-5?
Old Oct 30, 2005 | 05:16 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
try the search button...
this has been beaten to death...
Now, try to think if a 60* motor flange will fit a 90* motor flange...
If you think they can, go for it...
Old Oct 30, 2005 | 06:15 PM
3rdgenz4me's Avatar
I saw info on the automatic tranny swap but nothing on a 3.1 with a 5-speed to a small block. That is why I was asking.
Old Oct 30, 2005 | 06:21 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
dont let them beat you up, but do try a more thorough search next time. Cuts down on multiple threads with the same subject.
And the answer is no, that tranny will not bolt up.
Old Oct 30, 2005 | 11:20 PM
V6sucker's Avatar
Engine: blown up
and the manual would have a different bolt pattern for what reason...?
Old Oct 30, 2005 | 11:23 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
LOL, I was thinking the same.
Now, if you haven't bought this car yet, don't, go buy a factory SBC car, cheaper and (usually) more relieble than a conversion car.
Old Oct 31, 2005 | 12:27 AM
3rdgenz4me's Avatar
I should have thought the question through before I posted. However a simple yes or no would have been sufficient. Rather than mocking someones question with another question.
Old Oct 31, 2005 | 07:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 6 cyl T5 has the same bolt pattern with a different input shaft. Can have a V8 clutch disk fit with a V6 hub. Check the tranny boards lots of folks have done this. The threads will have the clutch manufactuers that they used (or just call around: RAM, McLeod, CF, Zoom).
Will need to use a V8 bellhousing.
RBob.
Old Oct 31, 2005 | 07:41 AM
3rdgenz4me's Avatar
Thanks for the information.
Old Oct 31, 2005 | 09:30 AM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
RBob.
i didn't think the v6s cars had a removable bellhousing? I was under the impression it was a solid unit unlike the 2 piece V8 T-5???
Old Oct 31, 2005 | 09:39 AM
V6sucker's Avatar
Engine: blown up
no they are 2 piece units.
Old Oct 31, 2005 | 12:07 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
the autos won't sway but the manuals will.........a t-5 is at-5 but a 700r4 isn't always a 700r4......lol gotta love it
Old Oct 31, 2005 | 03:53 PM
The_Raven's Avatar
There are differences in T5s too. There is less difference in 700R4s than there are in T5s.
formula_novice
Sep 5, 2015 03:58 AM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
