Rev limiter??
Old Oct 31, 2005 | 10:23 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Rev limiter??
Whats the highest I can rev my little 2.8 V6 MPFI?? I got ported intake and CAI dont kinow if thatll make a differance but Ive had it at 7300 and well it didnt sound healthy but at the same time looked like it was still pulling hard all the way up there.
Old Nov 1, 2005 | 06:26 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
stock internals are rated to 7k, mine pegs the limiter at about 6k though. i wouldnt run up to 7k on a high mileage top end though, keep it below 6k.
Old Nov 2, 2005 | 12:00 AM
Supermann's Avatar
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
The bottom end is rated to 7000, but def. not the top. Thing is, you need to get a lot of air flow at that rpm, and even with a ported intake and a cai, your heads would be the severe limiting factor. Most will say the car can't build any more power past 4500-5000 without some type of headwork. So no point revvin that high if you won't be making any extra power, its just gonna make something fail faster.
Old Nov 2, 2005 | 01:38 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
i read a GM document that someone had uploaded here that said our engines are good for 8000rpm but i would not do that or even close to that on a old wornout motor. heck i wouldnt do that on my brandnew one.
Old Nov 2, 2005 | 01:46 PM
Thanks for the input but its not completely answering my questio of is there a rev limiter? If not then how many rpm's can it reach stock.
Old Nov 2, 2005 | 04:49 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I have not seen in person a V6 F body that has one programed into the chip. I have had my 92 upto and floating around 9K a few times from missed shifts, so...
the only thing I have seen is the speed limiter at 110-116
Old Nov 2, 2005 | 05:05 PM
Is that speed limiter in all year third gens?
Old Nov 3, 2005 | 06:28 PM
V6sucker's Avatar
Engine: blown up
from what has been discussed, some 88-89, all 90-92
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
