Engine progress creeps on...Powdercoat finished
Old Nov 14, 2005 | 08:00 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Engine progress creaps on...Powdercoat finished
well as some of you know i have been slowing building up a 3.4L engine to drop in my camaro, most of the powedercoat work is done now and the engine is being taken int to a local shop to be balanced and assembled(short block) pictures of the powdercoat can be found here(easier for me to just link from another place as im on dial up) lemme know what ya all think so far
http://www.deadbird.org/swin//index.php?showtopic=181
Old Nov 14, 2005 | 08:50 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
looks good! you actually powder coated the block, too? i've wondered about doing that but I was scared of warping something.
Old Nov 18, 2005 | 08:53 PM
Pillsbry10's Avatar
it doesnt appear that any damage was done to the block, however the cam bearings got fried haha kinda forgot bout those but no big deal. i dropped the block off yesterday at the shop so hopefully in the next couple weeks ill have some assembled pictures.
now the question is what brackets to use 3.1 or the 3.4s does it make any diffrence. need to decide so i can powder coat those to
Old Nov 18, 2005 | 09:36 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Dang.. that does look good. But, I think for the sake of being a cheap-skate with $110 invested in a turbo kit and now $100 going into a full 3.4, I think I'll just call sand blasting and rattle can good
Old Nov 18, 2005 | 10:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
3.1 brackets. the 3.4 will be toooo long
Old Nov 19, 2005 | 12:04 AM
Car: 91 Camaro
yup. basically the only 3.4 stuff you'll use is the block and internals. otherwise you use what came from the car originally.
Old Nov 19, 2005 | 02:22 AM
Pillsbry10's Avatar
well thanks to a fellow member of the boards(deadbird) the powdercoat wasnt all that expensive, only reason i didnt go spray can was i wanted to be diffrent lol hence the buliding up a 3.4. now i can be like hey my engine is powdercoated haha
(wow i think i dran to much tonight...)
3.4 brackets will be to long...how so? only thing in my current state i can see that affecting is the powersteering pump right?
anyways time to pass out haha, hopefully ill have some good pics for you all some time soon
Old Nov 20, 2005 | 07:57 PM
Pillsbry10's Avatar
looking at timing covers today, was researching part numbers at the autozone today(was bored at work haha) and all are diffrent numbers so....which cover to use?
Old Nov 20, 2005 | 08:28 PM
Engine: 5.7 / 7.4
the 3.4 brackets extend from th block about 4~5 inches more than the 2.8/3.1 brackets.
Old Nov 22, 2005 | 11:14 PM
Pillsbry10's Avatar
ok now that i thought about it i see what you mean, can they be used...i thought i rememberd someone using them instead... i think it would look better with the powdercoating
can the 3.4 timing cover be used with the 3.1 brackets...i want to get that coated and would rather not take it off my 3.1 yet....
also random question...ive heard mixed optinons about the flywheels being neutraly balanced....well due to me not having it off the car yet and cant take it off yet my engine is being balnaced without the flywheel....looking opinions on if that will affect it any or not. some say yes some say no looking for some more opinions
also will 3.4 oil pan be ok, heard mixed opions on that as well about it rubbing exhaust and what not
think thats it for now...it went out for balancing today and hopefully will be back and together in bout two weeks
Old Nov 26, 2005 | 02:28 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
gotta use the 3.1 timing cover, oil pans are your call, and the flywheel i'm curious about too, i have another 88 2.8 that i got for free a while back and have the flywheel off that (neutrually balanced), would rather use it then buy a new one
Old Nov 26, 2005 | 04:19 PM
Pillsbry10's Avatar
hey project 85, i was looking at your website and it looks as though you used the new brackets, what all had to be done for that, im not going for steath to pass emissions or anything and wouldnt mind the more custom look, that and i dont wanna complely disable my car just yet if i dont have to, using the 3.4 at this point would be more convient
the machine shop agreed about the flywheel not being needed yet but was just wondering what everyone else thought
Old Nov 27, 2005 | 12:01 PM
Car: 91 Camaro
more than likely, the pictures you see on project 85's website are pics of his car with the 3.8 in it. that's why it looks like it does.
Old Nov 27, 2005 | 11:28 PM
Pillsbry10's Avatar
its a possiblity but i think the picture i was looking at was under the 3.4 secition, and had our intake on the top of the engine, i could be wrong just was curious
would really really help me out if the 3.4 timing chaing cover could be used instead of the 3.1 with no mods....
Old Nov 28, 2005 | 04:29 PM
Car: 91 Camaro
sorry, i hadn't looked at the pics i just assumed it was his 3.8 setup. but, you're right, those do look like the 3.4 brackets!
Old Nov 29, 2005 | 12:16 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Delay the answer as long as you can guys ... I've finally gotten back to working on my car and am enjoying the lack of other peoples things to work on , heh
Old Nov 29, 2005 | 04:52 PM
Pillsbry10's Avatar
hahaha i get this feeling im just gonna have to take my car apart, hopefully someone will know if i can use the 3.4 cover with the 3.1 parts as to save me some time and trouble
now we cant have you working on your own car that just wouldnt be normal so someone chime in soon so we can take deadbird away from working on his car
Old Dec 2, 2005 | 11:23 PM
Pillsbry10's Avatar
Rotating assembly is finished!!! woohoo, got the call today from the machine shop but didnt have a chance to go get it and snap some pics. they pretty much re did everything for me and upgraded everything possible so i cant complain with the pricey part of it
now that thats done the rest is gonna probably have to wait till after the holidays.....stupid xmas lol, anyways hopefully ill get some pics up soon
still waiting if anyone knows if the 3.4 cover will work, looking for someoen who has tried it not just a general use the 3.1 lol
Old Dec 3, 2005 | 12:02 AM
Car: 91 Camaro
just to mix things up more...the two look the same to me. but, i know that looks can be deceiving. the only difference that i KNOW of is that 3.4 timing covers don't have the timing tab since its all computer controlled (DIS).
Old Dec 3, 2005 | 02:34 PM
Pillsbry10's Avatar
haha thanks for the input.... i agree with you on them looking identical, the only thing i can think that would be a problem is maybe a bolt whole being a diffrent size or in a diffrent location.
with the timing marks im gonna powdercoat it anyways lol so either way im gonna have to make up my own marks to put back on so i could just compare with the 3.1 cover and transfer it over
hey ams91....havent heard much on the intake you made, you still plannin on making them to sell with the bigger TB, gonna be looking into that as the engine continues to be built
Old Dec 3, 2005 | 04:05 PM
Car: 91 Camaro
going by the fact that the blocks are the same other than cylinder sleeves being thicker in the 3.4s and the imfamous "F" cast on the side of the 3.4 block, i don't imagine the bolt holes on the timing cover are different. also, if you can use the 3.1 cover on the 3.4 block, you should be able to use the 3.4 cover in your car. powder coating the timing tab won't matter, though; because it has the "jagged" edge which indicates every 2 degrees (if i remember correctly). so, you won't have to be able to see the numbers. but, you can often still see numbers and things even with powder coating on top.
for the intakes, yes, I do still plan to do that deal. I am working on a TB for a guy now and have some materials to work on the manifolds I just need to get the time to build them.
Old Dec 3, 2005 | 08:24 PM
Pillsbry10's Avatar
well....i guess ill just go with the 3.4 cover and see what happens if it doesnt work ill just have to take the car apart. i just hope i can get teh timing marks on the 3.4 cover so that it times right...that could be the biggest challenge....thanks for the input, just wanted to double check with some people. still wondering if project used the 3.4 brackets cuz those would look way better in the car
as far as the intakes go im definitly interested in that and the tb, just need to figure out how big of a tb i should go with with this engine any ideas? are you just gonna do a group buy or is this gonna be something thats available anytime.
next step....head work woohoo all the places around here want way to much, but to send them off to supersix isnt gonna be much cheaper....anyone had there heads done there?
Old Dec 4, 2005 | 12:20 PM
Car: 91 Camaro
I can't remember off hand and the 3.4 cover that I have is at the shop but you might be able to take the timing tab off of the 3.1 cover and put it on the 3.4 cover when you are doing the swap. I think its just screwed on but you might need a "special" tool for the screw.
if you want to send me the motor specs for your new motor, I'll try to recommend a TB size for you. I think I'll just have them available "whenever"; might be a "made to order" type deal, also.
Head work isn't too hard if you want to attempt it yourself. If you've never done it before, I would reccomend only "cleaning up the casting marks"...don't go crazy on them and you should be okay.
Old Dec 4, 2005 | 05:22 PM
Pillsbry10's Avatar
hmm ill look at the cover and see if the tab comes off, would be nice if it did
you have a pm
ive never really done any head work nor do i have the place or tools to do it at this point. i want to get them done proffesionaly, im trying to get as much power outvve this motor NA before i put a power adder on it. as much as i hate waiting for this engine to get finished im trying to do everything right on it as to not have to rebuild it anytime soon
well this could put a damper in my engine build and xmas....check it out and vote
http://www.deadbird.org/swin//index....t=ST&f=2&t=201
Old Jan 29, 2006 | 11:24 PM
Pillsbry10's Avatar
well aside from the comunity service i now have to do everything is back on track....
engine is almost fully assmebled, heads are ported and polished and am working on getting the hardware together for the heads
started tearing down my engine in the car so that should hopefully be complete within a week or two(work permiting)
hopefully i will be adding an intake and TB from am91camaro....
also looking for upgraded distributer...possibly msd?
also wanting to buy new injectors? suggestions there also needed?
hopefully i can get some assembled pictures up some time soon...that way all of you can check out how good the powdercoat is looking.
think thats all for now
Old Jan 30, 2006 | 01:17 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i couldn't find anything from msd for the 3.4 i'm building, but mallory makes a few nice ones
might want to look into them
Old Feb 1, 2006 | 01:45 AM
Pillsbry10's Avatar
did you call them cuz ims ure they wont list it in any catalogs(msd that is) ill look into mallory but id like to have matching stuff if possible
im picking up a msd ignition and blaster coil from work for pretty cheap both for around 250. its the msd model 6al with rev limiter and a few other goodies and the blaster 2 coil
Old Feb 1, 2006 | 05:20 PM
Car: 91 Camaro
you can get a msd cap and rotor. i don't know if they list it specifically for our cars but look it up for a 94 s-10 4.3...its the same; that's what i did.
Old Feb 1, 2006 | 05:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Back 2 years ago, nobody but um.. forget made a distributor.
Few weeks ago I looked when the topic came up, looked like mallory just started making one. But no pictures so I am not sure if its carb or EFI application.
Old Feb 4, 2006 | 01:18 AM
Pillsbry10's Avatar
hmm...well looks like ignition will be as follows
MSD 6al ignition box
MSD Blaster 2 Coil
MSD Cap Rotor(thnaks am91)
and whatever distributor i can find to upgrade to...ill check on mallory any other ideas?
also ides on injectors will be needed very soon lol
heads are almost done and equpped lol....give specs on them when i get them back
Old Feb 9, 2006 | 05:10 PM
Pillsbry10's Avatar
well got some pics up for you guys on the other board, check them out, heads are almost ready for assemble just waiting on parts woohoo.....and the bill haha lemme know what ya all think
http://www.deadbird.org/swin/index.p...t=30#entry1324
Old Feb 11, 2006 | 02:11 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
mallory makes a few "performance" efi distributors for our cars.
msd doesn't make anything
only other option is pertronix.
Old Feb 11, 2006 | 02:24 AM
Thunderfest's Avatar
Looking very nice. I would caution you though to pull out the steel freeze plugs and use brass, they are cheap and good insurance. brass lasts much longer.
Old Feb 11, 2006 | 09:18 AM
Dale's Avatar
Engine: 350 S-TPI
Nobody does, cardone is the only other dizzy besides gm.
Infested
May 22, 2018 11:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
