How do you test the ECM
Old Dec 1, 2005 | 08:07 AM
dxacer01's Avatar
Car: 89, 87, and 84 Firebirds
Engine: 2.8. 2.8, 350
How do you test the ecm on a 2.8 1989 Firebird?
Old Dec 1, 2005 | 10:21 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
What problem are you having, there is no way to directly test the ECM, you have to check sensors and outputs first, then if everything else checks out OK, then you have to replace the ECM with a known good unit. If the problem is solved, it's the ECM...it's aminly trial and error.
What issues are you having? ECMs don't go bad as often as people like to think they do. Most problems lie in sensors and outputs of the ECM.
Old Dec 2, 2005 | 10:08 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
QFT!
There is a way to test the ECM, but a simulator has to be built and you have to know EXACTLY what you are looking for/at, to determine if it's fuctioning properly, or not.
Old Dec 3, 2005 | 10:12 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
OK, I stand corrected, but for a normal person, there is no way to test the ECM itself.
And what the hell is "QFT"?
Old Dec 3, 2005 | 11:56 AM
The_Raven's Avatar
QFT! = Quoted For Truth
Yeah, I only mentioned it because it's possible, but not nessisarily feasible.
KCG
Jun 24, 2020 04:33 AM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
eustodp
Sep 20, 2015 05:09 PM
