Strange Find On Timing Chain Info
Old Dec 8, 2005 | 10:07 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I've debated on contacting a company to make a gear drive set for our engines. This replaces the timing chain with 3 to 4 gears eliminating the "chain stretch" that is commen with our engines. Before approcing I wanted a list of all cars/engines this would fit to make it seem like they would fit a broad market, rather then just a handful of cars.
Anyway, I found out that most our engines use GM# 14102670. Same as s10, citation, few other gm rides.
It is NOT the same as the FWD cars, so I looked that up.. FWD cars use 14102671.
After looking this over....
It says that 1987 to 1990 FIREBIRDS use the FWD chain? But 82-86, and 91-95 use the RWD chain.
It also says that on the feiro 85-86 models use RWD, and 87-88 use FWD chain.
This is raising a big WTF to me.
Does anyone here have a FWD engine/chain sitting next to a RWD engine/chain to compare for me? Could this MFG possibly make it universal to fit FWD and RWD for a bigger market?
Also while posting this. Who would be interested in such a product? Price I am guessing to be between 75-150 bux.
Old Dec 8, 2005 | 02:40 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
The difference between the FWD and RWD chains is thickness. The RWD chain is thicker (accross the chain and sprockets) than the FWD variant. I don't remember exact difference, but it was between .100" and .125".
The chains can be swapped between FWD and RWD. Some FWD timing covers will need clearancing though, but I can only confirm this for the Cloyes double roller, which I believe is thicker than the RWD chain.
The Crank snouts are the same between RWD and FWD, and the Cam sprocket pattern is the same between RWD and genI and genII FWD. The genIII (3100/3400) uses a single large bolt for attachment.
So the fitment list you are looking for would be:
S-10 '82 to '94
F-body '82 (?) to '96
Cavalier '85 to '94
Sunbird '91 to '94
A-body '85 to '90 (I think that was the last year)
X-body '82 to '??
P-body '85 to '88
Firenza '87 to '89
Cimmaron '85 to '89 (I'm pretty sure the Firenza and Cimmaron were both available up to '89)
W-body '89 (?) to '93
I'm sure there are others, but that covers most of it.
I know there would be a few guys in the J-body comunnity that would be interested in a gear drive.
Myself, I won't run one, to many harmonics created, or passed from the crank to the cam, also too loud to hear anything else.
I'm more interested in a timing belt.
Old Dec 8, 2005 | 03:08 PM
Dale's Avatar
Engine: 350 S-TPI
I was always under the assumention the chains on the fiero and firebird are the same.
However, if you go to gmpartsdirect and do a reverse search, they are not the same.
The gear drives, you can get silent or noisy. Your choice I want the noise Thanks for info on why the chains are different.
As for a list
RWD(or RWD chain):
Buick centry 86
Buick skylark 80-85
Astro 85
Camaro 82-95
Caprice 85-86
Cavalier 85-86
Celebrity 82-86
Citation 80-85
El Camino 85-86
Impala 85
Monte 85-86
S10 pickup/blazer 82-93
s15 " " 82-93
Cutlass Ciera 82-86
Cutlass Cruiser 85-86
Omega 80-84
6000 82-86
Fiero 85-86 (I thought tell 88)
Firebird 82-86,91-95 (as it states and my strange finding)
Phoenix 80-84
*breathes*
FWD (FWD chain)
Centry 87-89
Regal 88-93
Cimarron 85-88
APV 90-93
Beretta 87-93 (guess they dropped the v6 after 93?)
Cavalier 87-94
Celebrity 87-90
Corsica 87-93
Lumina 90-94
Lumina APV 90-95
Cutlass ciera 87-89
Cruiser 87-89
Supreme 89-93
Firenza 85-87
Silhouette 90-94
6000 87-91
Fiero 87-88
Firebird 87-90
GP 88-93 (think higer)
Sunbird 91-94
Transport 90-95
*sigh*
Old Dec 8, 2005 | 05:20 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I'd be interested, seems like it's gonna be a pain to change the timing chain and I'd like to not have to do it ever again.
Old Dec 8, 2005 | 05:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Note that there can also be a cam timing difference between the two chain setups.
RBob.
Old Dec 8, 2005 | 07:27 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Regarding silent or noisy, what kind of noise do gears make?
Old Dec 8, 2005 | 07:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Straight cut gears howl, can be heard for miles. Tapered (or angle cut) are quiet but create side or end thust.
RBob.
Old Dec 8, 2005 | 07:49 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
is it an annoying howl or like a turbo kinda howl?
Old Dec 8, 2005 | 08:49 PM
Dale's Avatar
Engine: 350 S-TPI
They sound kinda like a supercharger kicked on 24/7.
Best I can explain is watch one of the first sceans (sp) on fast and furious one. Where they pull up to the sandwich shop and the blue car is making a noise. Its very similar to that.
Rbob, is the 2deg advance/retard not possible on a gear setup, just chain?
Old Dec 8, 2005 | 08:50 PM
ladyfirebird's Avatar
Car: 94 Firebird
Engine: 3.4
Comprable to a turbo kind of howl. If you drive the car frequently every day, it gets annoying sometimes.
Old Dec 8, 2005 | 10:12 PM
The_Raven's Avatar
Dale: The L-body (Beretta) changed to the genIII 660 in '94, hence why the chain won't fit '94+
I don't understand this timing difference between the two chains. If you install the cam straight up, with either chain they are straight up.
Old Dec 9, 2005 | 06:50 AM
Dale's Avatar
Engine: 350 S-TPI
Is the gen 3 so far off that it couldnt be incorperated either?
Old Dec 9, 2005 | 10:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Should be able to make it +- any amount (within reason). Cut three key ways in the crank gear, and place three different marks on it. One Cloyes chain for the SBC has 0 , +4, and -4 degrees.
All I mentioned is that there is a possibility that the chains may have different timing. Why would the same engine in the same car use two different chains from one year to the next? GM has been known to do this kind of stuff. For years the stock GM chain for the SBC was set to +6 degrees. Worked fine when used with GM cams, not so good with aftermarket cams.
Dale, is there a cam difference between those years that use a different chain? For some reason I don't think there is.
RBob.
Old Dec 9, 2005 | 10:23 AM
The_Raven's Avatar
Yes, very different. The genI/II use 3 6mm (IIRC) bolts to retain the cam gear to the cam.
The genIII uses one large bolt, approximatly a 13mm diameter thread, to retain the cam gear to the cam.
The difference between the gears is thickness of the chain. there is no change in cam timing.
Old Dec 9, 2005 | 11:29 AM
Dale's Avatar
Engine: 350 S-TPI
RBob.
Cloyes for the v6 has a +/- 2 I belive? Been a while since I had one.
As for cam difference, I dont think so for the bird. Doubt it on the fiero.
Raven, thanks for the info.
Old Dec 9, 2005 | 05:10 PM
TransAmMike's Avatar
Car: 91 Firebird
Engine: 3.1 v6
Transmission: Automatic
Since we're on the topic of timing chains and I've been having a hard time finding a replacement one with solid information behind it, can someone recomend a good timing chain for my '91 3.1? Preferably something made for performance application.
Old Dec 9, 2005 | 05:46 PM
The_Raven's Avatar
I'm using a FWD replacment in my hybrid. I thought I ordered the RWD part, but crossed the numbers.
BTW I laid down 218 HP and 270 ft/lbs when I was at the dyno last, through a T-5 and 7.5" rear using 3.73 gears. so you can make the call there.
Old Dec 9, 2005 | 08:36 PM
Dale's Avatar
Engine: 350 S-TPI
Cloyes makes a double roller chain that is for our engines, and its make about 1 hour away from me
Above in this thread, or in another posted this week crane now makes 3 peformance chains.
Old Dec 9, 2005 | 08:38 PM
Dale's Avatar
Engine: 350 S-TPI
At the tires correct? Whats that est out to at the fly?
Old Dec 9, 2005 | 09:38 PM
Dale's Avatar
Engine: 350 S-TPI
Found out cloyes makes gear drives, and sells them to edlebrock. Searching on there site, I found this
Accu-Drive® Gear Drives are not recommended for use above 7,000 rpm or on computer-controlled vehicles with knock sensors.
So yes, this is now dead in the water. But I did find alot of info.
Double roller it is for me next time
Old Dec 11, 2005 | 02:21 AM
The_Raven's Avatar
Approx. 250 HP and 310 Ft/lbs.
Old Dec 13, 2005 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Although for the 2.8 guys, we don't have knock sensors so we don't have to worry
I've got the Cloyes true dual roller chain/sprocket set in my car, I put it in at 186,000 miles. Can't use the stock tensioner anymore because the new sprockets hit it (the box has the directions in it- "remove stock tensioner").
Now I'm at 291,000 miles, so the chain is definately durable
Old Dec 13, 2005 | 02:39 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I would be interested in a not so noisey one.
Old Dec 14, 2005 | 11:05 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What're the odds of getting an idea of the slack you've got in it?
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
MY87LT
Aug 17, 2015 08:43 AM
