strange problems, temp, volt, 02 rich
Old Dec 20, 2005 | 01:49 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ok i just got a new exhaust Y, I, and axleback duals. new 02 as well. my rad is leaking a bit. im looking for a new one.
this is what is happening. ill be on the highway cruising and come to a stop on the off ramp. my temp starts climbing immediatly till the light comes on, and my volt starts dropping and my lights dim. i hit the gas, the lights get brighter and the volts rise, temp falls. then my car seems gutless not much power. (this happenes every night) i park in the driveway and my ses light comes on with code 45, O2 rich. (this is the first time this has happened) i can get a replacement for the O2 because its a week old. and ive had my alt and battery tested twice. i cleaned the contacts on the alt and the grounds. made sure the belt is tight and the alt pully spins freely.
1 why is my volt going down
2 why is my temp rising and my fan not coming on right away.
3 what could cause a rich condition or is the O2 faulty.
im going to clean the cap and rotor, im thinking when the temp rises there isnt enough spark due to dirty terminals.
im not running out of coolent i checked it when i got home.
Old Dec 20, 2005 | 12:56 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
see if the fan spins with almost no resistance cause my parents minivan was doin kinda the same thing and it was the fan motor mostly seized and when you would hit the gas it made enough Juice to force the fan to turn but when you let off it would slow down again and all the lights would dim. we unpluged the fan and everything in the car but it worked ok. dont know if that is your problem but i would check it.
Old Dec 21, 2005 | 01:54 AM
Car: IROC Z
Engine: 5.7
well by the time i got home today i had to hold it almost to the floor to get it to go anywhere
so i think its 2 unrelated issues.
i think i saw an arc on one of the wires when i had the hood up, but i dont think one little arc would make my car almost undrivealbe. and it idles fine.
im going to do plugs caprotor and wires maybe tomorrow. damn i dont need this right now.
Old Dec 21, 2005 | 05:45 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
1. Could be because the alt gets hot, and doesnt deliver as much power as it normally does. as well as its at idle now, rather then driving rpm. Mine does this, doesnt sound as drastic though.
2. Engine is hot, engine bay is hot. While your driving your coolant is being circulated quite fast due to engine rpm. You slow down... you have less air moving over radiator, your wp isnt moving the coolant as fast. So engine gets hotter. Again, mine does this. I have electric fans on toggle switches and I turn them on soon as I'm driving down the exit ramp.
3. Would have to tinker with the car. Having same problem myself right now.
Old Dec 21, 2005 | 09:49 AM
Car: IROC Z
Engine: 5.7
last ngiht with the volt and temp in medium range the car still had problems moving. it wouldnt rev up very fast i had problems climbing any slight hill at all
Old Dec 21, 2005 | 10:39 AM
Car: IROC Z
Engine: 5.7
spun the fan by hand it spins freely.
i took off the cap and rotor and cleaned it, looked fine.
took out the #6 spark plug it looked fine, wasnt even dirty.
i didnt take out the other 5 as its -6C put right now ill get to them in a bit.
Old Dec 21, 2005 | 12:36 PM
Car: IROC Z
Engine: 5.7
this thing is slow
it doesnt even rev by the throttle blade fast at all
i unplugged the maf and put in a different tps sensor but still no change
could it be a bad o2?
what would cause a rich condition
Infested
May 22, 2018 11:56 PM
dyeager535
Aug 28, 2015 08:10 AM
red90IROCls1
Aug 25, 2015 06:56 AM
