Dales 3.4 swap tech artical.
Old Feb 14, 2013 | 01:38 PM
  #101
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Re: Dales 3.4 swap tech artical.
I can get a brand new block 3.4liter 1995 Camaro from napa 3 year warranty unlimited miles. Heads, complete, gasket set, oil pump
What other parts would I need for my 3.1L to 3.4L swap.
3.4 fuel injectors
3.4 harmonic balancer (i need this right?)
3.4 knock sensor
3.1 stock water pump ok ?
Old Feb 14, 2013 | 05:08 PM
  #102
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
That engine may come with a balancer. But your 3.1 should work, but I didnt try that.
3.1 wp will be fine.
Old Feb 14, 2013 | 10:13 PM
  #103
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I used my 2.8 one just to be on the safe side, but I don't believe there is any difference in them.
2.8, 3.1, and 3.4 water pumps are the same.
Old Feb 15, 2013 | 06:53 AM
  #104
Dale's Avatar
Engine: 350 S-TPI
Need to becareful here. Some of the 2.8's are external balanced which means the balancer and fly/flex matches the crank. Some are internal, which means all parts are by itself.
Also, some waterpumps are different. This depends if if your running v-belts, or serpentine belts.
Old Feb 15, 2013 | 09:54 AM
  #105
Car: 1989 Camaro RS
Engine: LH6
Would the older 2.8s be externally balanced? Mine was a 89 2.8 and I used its Belt system, haven't had problems yet.
Old Feb 15, 2013 | 08:51 PM
  #106
Dale's Avatar
Engine: 350 S-TPI
Correct. There has been some controversy as to when they switched. Its easiest to say 2.8's cant, and 3.1's can reuse it.
Old Feb 15, 2013 | 11:39 PM
  #107
Car: 1989 Camaro RS
Engine: LH6
I guess its too late now lol. I've got a 2.8 balencer and flex plate.
Old Mar 3, 2013 | 11:05 PM
  #108
KG427KG427's Avatar
Car: 1991 camaro
Originally Posted by Maverick H1L
The only parts you need to swap from the 3.1 are the fuel rail and upper plenum (maybe the intake manifold to heater core pipe), and the accessory brackets and accessories, along with any possible sensors that don't match. The fuel injectors and everything below stay with the 3.4. Do a water pump and as many gaskets as you can while the engine is out.
Stupid question but can you use your 3.1 plunum if your going to use a 3.4 block and 3.4 exhaust manifolds and 3.1 valve covers ?
Old Mar 3, 2013 | 11:48 PM
  #109
Car: 1989 Camaro RS
Engine: LH6
Yes, it all bolts up. Although I think the 3.4 manifolds router slightly different. I'm not sure.
Old Mar 4, 2013 | 05:41 AM
  #110
Dale's Avatar
Engine: 350 S-TPI
3.4 manifolds have o2 sensors in them. They dump in very similar place. I know one person who didnt even change these and was able to make a 2.8 y-pipe bolt up to them.
Old Apr 3, 2013 | 03:36 AM
  #111
alienbishop's Avatar
Car: 1991 Camaro RS
Engine: In the process of swaping to 3.4
Transmission: Automatic
Hi, I finaly started my swap, i already installed my 3.1 intake manifold to my 3.4 block, but i have another problem, i don't have any reference to continue, there are alot of wires, pipes, brackets, i want to do it as good as possible, as close to original factory conditon as possible, when everythingis on its palce, all the stuff is routed and mounted as it should be, can someone point source with detailed info on thirdgen 3.1 engine installation, or atleast detailed photos to see how is all the stuff mounted and assembled. Making photos from my own car before dissasembly would not make sense, because i already got it abused, partialy disassembled and "repaired" by some asssholes.
Old Apr 3, 2013 | 05:49 AM
  #112
Dale's Avatar
Engine: 350 S-TPI
I dont have a 3.1 anymore. Someone else will have to help here on that. However, if I remember right, other then the fuel rail harness. You should beable to fully assemble the top, then route the main engine harness around and where it needs to go.
Old Apr 3, 2013 | 05:53 AM
  #113
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
@alienbishop
Between this link https://www.thirdgen.org/forums/v6/6...-fasteddi.html and this link https://www.thirdgen.org/forums/powe...o-time-v3.html there are many pictures of a 3.1L assembled.
There should be enough pics to help you a tad on what the engine looks like when assembled correctly. The only bad thing is I dont have any emmisions at all hooked up. I have tons of pics on my computer even when it had emmisions so just pm me for specific pics if you want.
Old Apr 3, 2013 | 07:55 PM
  #114
zero16lives's Avatar
Car: 1989 Camaro RS
Engine: V6 2.8L
Transmission: 5 Speed Manual
I think this belongs here, if not let me know and I'll delete it and create a new thread. So it looks like I'm going to buy a used/reconditioned short block to replace the 2.8L in my '89 camaro. So this may be a stupid question but since the 2.8/3.1/3.4 are so similar could I buy a 3.4 short block and use parts from my 2.8 and bolt it up? Would I need new heads and possibly other parts? Better to just buy a long block? Thanks.
Old Apr 4, 2013 | 01:03 AM
  #115
Car: 1989 Camaro RS
Engine: LH6
I have pictures from my 2.8, its close to the 3.1, but not exact, I can send them if you are interested.
All you need is a long block. Oil pan, intake manis, exhaust manis from the 2.8 go on the 3.4. Essentially you are recreating the 2.8, but with the 3.4 block and heads.
specialized
Jun 18, 2022 09:26 AM
JHX
Sep 21, 2015 08:53 PM
gixxer92
Sep 1, 2015 04:32 PM
sailtexas186548
Aug 24, 2015 10:11 PM
92projectcamaro
Aug 6, 2015 01:20 PM
