setting rev limiter
Old Jan 18, 2006 | 08:55 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
setting rev limiter
Is there any way to move the rev limiter up like another 500rpm's? I used to be able to rev mine right up past 7K but now it limits at 6K. I dont want it to go past 7K now that I know the internals cant hanlde it but I dont want it to cut out at 6K. I was thinking 6500 should be good. And before you ask why would I do this Ill give you reasons. I got a turbo going on soon and Im gonna be getting a higher rpm cam to match it a little better and I know that the power band is gonna shift up so I want more rpm to go through. Thanks
Old Jan 18, 2006 | 10:03 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
You used to be able to do it, but now you can't? The rev limiter is built into the ECM, IIRC, there's no way to change it without a new chip, plus the fact that I don't think an 86 has a rev limiter built in. If you used to be able to do it, but now you can't I would start looking at the ICM or possibly the Pickup coil as possible problems as to why you aren't getting an ignition pulse signal up that high in the RPM range.
Old Jan 18, 2006 | 11:10 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
my 85 will go to 6500 and start bouncing back to 6000 and that is with every thing stock and working good and with two different ECUs one a good junk yard one and the current one a new remaned one.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Sep 4, 2015 07:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
perZ
Aug 15, 2015 01:17 PM
